Limits on sending emails
- Re: Limits on sending emails
20-08-2009 11:48 AM
If I remember correctly there is also a tarpit limit which slows the sending of emails above a certain amount.
I want to set up a low volume mailing list run from my desktop and I want to set some realistic limits so I don't get jumped on, but I cannot find the limits anywhere on the portal page.
20-08-2009 11:52 AM
There's currently no limits on the number of emails that you're allowed to send per hour.
Can I ask how many emails that you are looking to send? Would something like a blog for your readers to follow via RSS possibly be more applicable (and easier for you!)?
20-08-2009 12:11 PM
It's a closed group, so a blog is not appropriate.
I do not envisage the group exceeding 100 and if it does, then we will have to look at some other solution. Emails to the group are likely to be once per month or perhaps as much as once per week, but unlikely to exceed any of these limits.
20-08-2009 12:18 PM
20-08-2009 12:20 PM
20-08-2009 12:21 PM
What is the advantage of the mycircular option
Have Plusnet stopped tar-pitting emails
20-08-2009 12:21 PM
BCC - essential for such a group
Quote from: itsme By the sound of it you are not going to use a bulk email services so I assume that you will setup a group within your address book which could leave all the emails addresses in public view within the group. Which some may not be happy with. An alternative is to use PN Circular https://portal.plus.net/office.html?action=mycircular&?membermenu=mycircular
20-08-2009 12:30 PM
Quote Warning: The hiding of the Bcc: addresses from other Bcc: addresses is not required by RFC 2822 and so you should never assume the Bcc: addresses will be hidden from other Bcc: addresses.
20-08-2009 12:48 PM
What I can say from experience is the Bcc emails sent using Outlook Express and Outlook fully hide the Bcc addresses.
20-08-2009 1:07 PM
The only totally safe way is to use software which sends an individual email to each client - I believe that is what MyCircular does.
20-08-2009 1:33 PM
Am I understanding you correctly - it is nothing to do with the email program you are using to send or receive but with the receiving server (i.e. mail.plus.net) and how it handles them
Also part of my original post - have Plusnet stopped tar-pitting bulk emails
20-08-2009 2:01 PM
I would imagine if there's an email BCCed, then the client will just send extra rcpt to: <address> commands to the server. However, if it then sends BCC: in the actual header section:
To: Colin Ogilvie <colin@myHomeComputerIPHostname>
From: colin Ogilvie <me@myPlusNetUsername.plus.com>
Bcc: Colin Ogilvie <me@myYahooAccount.co.uk>
Subject: Testing BCC
it would be up to the server to strip that I guess...
although I'm not sure if that's really relevant to the subject at hand!
20-08-2009 2:05 PM
20-08-2009 2:22 PM
I just wanted to add that the warning in wiki could be right because some email clients do not have BCC as an option (ie Apple's mail)
just a thought.
20-08-2009 2:30 PM
