Limiting ethernet ports through telnet or ?
- Re: Limiting ethernet ports through telnet or ?
06-06-2013 3:07 PM
06-06-2013 3:29 PM
What are the sync speeds shown in your modem status page ?.
06-06-2013 3:47 PM
Uptime: 0 days, 3:51:38
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5,280
Data Transferred (Sent/Received) [MB/MB]: 21.68 / 407.94
Output Power (Up/Down) [dBm]: 11.9 / 20.0
Line Attenuation (Up/Down) [dB]: 22.0 / 35.0
SN Margin (Up/Down) [dB]: 25.0 / 9.7
Chipset Vendor ID (Local/Remote): BDCM / ALCB
Loss of Framing (Local/Remote): 17 / -
Loss of Signal (Local/Remote): 25 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 115 / -
FEC Errors (Up/Down): 170 / 3,376
CRC Errors (Up/Down): 147 / 235
HEC Errors (Up/Down): -47 / 235 / 1,009
06-06-2013 4:14 PM
Quote from: Superted http://www.kitz.co.uk/adsl/max_speed_calc.php
I've recently been moved to ADSL2, I believe the process will complete over the next few days. Here is my link info.
Your DSL Type being "G.992.1" is still just "up to 8Mbps" ADSL. http://en.wikipedia.org/wiki/G.992.1
When it has changed to ADSL2 then the status should indicate "G.992.3" or "G.992.5"
Using the Kitz ADSL speed calculator, it looks like your download speeds should double on ADSL2 -
Once your line has changed to ADSL2 or ADSL2+, come back to this thread and ask the Plusnet staff to uncap your upload speed, which will probably then also double !.
After all that, then see if you still have problems !
06-06-2013 4:19 PM
Those ADSL stats don't look very good, speed slightly low, high SNR margin, too many Loss of Signal errors. The Loss of Signal errors could be something to do with the router on 20CN ADSL1, and might go away once you're switched over to ADSL2+.
06-06-2013 4:33 PM
ejs, the QoS was on the up and down, just for testing purposes, the line is pretty terrible out here and I was advised by support ADSL2 would be more stable. Over the past few months I've had many problems, so prioritizing my internal traffic is sort of where I ended up.
Cheers for your comments guys, if it doesn't work out I might have to get a tomato capable modem and limit every wireless device to dial up speeds
06-06-2013 5:32 PM
07-06-2013 9:33 AM
I can see we have an order in place to move you over to ADSL2+, we'll need to place an order to uncap your upload once this completes.
08-06-2013 3:12 PM
10-06-2013 11:32 AM
You shouldn't do, nothing needs to change at your premises and the router you've got will work fine on ADSL2+. Looks like the order is due to complete on the 19th (so, next Wednesday), hope it improves things for you.
16-06-2013 9:51 PM
17-06-2013 2:01 PM
17-06-2013 2:56 PM
19-06-2013 9:13 AM
21-06-2013 12:08 AM
