Just a quick question about line stabilising at a set rate
- Re: Just a quick question about line stabilising a...
29-03-2010 12:17 PM
I'm just wondering about this whole 10 day training period, when have current NEW customers such as paulpicks21 and Nittygritty experienced anything faster than the speed i'm getting at the moment which according to speedtest.net is 3.89 meg connection, and for Plusnet staff does it usually take the full 10 days before the line syncs at the fastest speed it can get?
Thank you
P.S) Just want to also say I think it's brilliant the speed Plusnet staff respond to queries, great job.
Re: Just a quick question about line stabilising at a set rate
29-03-2010 1:14 PM
I'm not sure what the first part of that question relates to, but your sync speed will depend on your individual line conditions.
During the training period it's best to reboot once a day, in the morning if possible, as that's when the conditions will be best. This should up your speed if there's anymore to be gained.
29-03-2010 1:26 PM
Oh and my line conditions i'm not sure about but I'd think they should be pretty good as when I moved into this house it had no phone line at all so I had a brand new line installed by B.T back in June 2009 so the condition of the line better be good lol because it cost me £122.99 for a new installation!! Oh and i'm also not too far from the exchange 1.03km in fact
29-03-2010 1:29 PM
p.s the first day i switched i had great speeds,didnt need to wait for the so called 10 day rule, if your getting 3mb+ now i wouldnt have thought it would shoot up much, after 10 days, suppose it depends on what time of day u using it aswell i suppose, some days u may get higher if u use in daytime, just depends on how far u are away from exchange, if u using master socket, etc etc, all of which have an impact in someway shape or form on how good ur speeds will be. main thing is its not as bad as virgins, lol,
29-03-2010 1:52 PM
I'm sure it will sort itself out soon enough, I'm only on day three anyway lol, oh and I'm not far from the exchange at all only 1.03 km.
I agree with you though it's not as bad as Virgin at all!
29-03-2010 2:14 PM
But BT Speedtester says I have an assured rate IP profile of 4000 kbps, is that right?
30-03-2010 12:37 AM
Chris
30-03-2010 9:30 AM
From router stats - Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Bt speed tester says my line profile is 7150
And the speed tests always indicate 6.5-6.6 meg
On samknows it states I live 730 mtrs from my exchange.
And if I run a check on BTs website to see what my line can support it says 7meg so I am pretty much bang on with that and happy.
Cheers
Paul.
30-03-2010 9:43 AM
I will flag this up for more visibility
30-03-2010 9:46 AM
I've just rebooted my router and it now says DownStream Connection Speed 5728 kbps and just ran that BT speedtester and it still says Your configured download throughput speed for this service is 4000 k so I dunno I'll just have to see what happens, and why would B.T have locked the profile oldjim? Because with my old ISP (even though they were pretty bad!) I got a better throughput than 4000k.
Here's what the BT speedtester said,
Download speed achieved during the test was - 3583 Kbps
For your connection, the acceptable range of speeds is 600-4000 Kbps.
Additional Information:
Assured Rate IP profile on your line is - 4000 Kbps
Just for the record the connection is stable enough just not as good a throughput as it was when I was with my old ISP.
Thank you
30-03-2010 9:50 AM
It may be related to the future change to 21CN where banded profiles appear to be causing some annoyance
30-03-2010 9:52 AM
Will check back later anyway, got things to see and people to (well you get the idea) lol
Thanks for replying
30-03-2010 10:02 AM
BT Wholesale (or is it BT Openreach) are the ones who create the IP Profile and also lock them
30-03-2010 12:11 PM
Quote from: Mand During the training period it's best to reboot once a day, in the morning if possible, as that's when the conditions will be best. This should up your speed if there's anymore to be gained.
I rebooted my router this morning at 10:30am and i'm connected with a downstream speed @ 5696 kbps but I won't see that speed if my IP profile is locked at 4000 kbps and oldjim said he would flag this up for higher visibility so could someone from Plusnet please look into this for me and I'll check back later see what's what.
Thank you.
30-03-2010 12:29 PM
