James - Can we uncap my upstream again please?
- Re: James - Can we uncap my upstream again please?
19-10-2009 1:16 PM
My upload speed was capped over the weekend to see if it made any difference to my downstream sync rates. Unfortunately it made no difference so is it possible to put the upstream back to its uncapped state please?
Thanks for all your help so far.
19-10-2009 1:17 PM
I'll get the order placed now.
21-10-2009 1:09 PM
I'm away from home atm so I cant change my current upload sync rates. Has my upstream been uncapped yet?
Cheers
21-10-2009 1:15 PM
21-10-2009 1:26 PM
21-10-2009 6:24 PM
Quote from: Jameseh According to BT, your order has completed.
I'm not sure why but I'm seeing no change since rebooting the router a few minutes ago this-evening:
Uptime: 0 days, 0:12:08
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3,335
Data Transferred (Sent/Received) [kB/MB] 447.29 / 1.60
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 27.0 / 47.0
SN Margin (Up/Down) [dB]: 19.0 / 9.5
As you can see, the sync rate still appears to be capped.
I really hope the old sync rate can be restored because it was the only advantage I had to being on 21CN!
22-10-2009 7:48 AM
22-10-2009 8:49 AM
I take it things have been pretty stable recently?
22-10-2009 10:31 AM
With this band in place my connection is identical to 20CN
Cheers
22-10-2009 11:47 AM
22-10-2009 3:05 PM
24-10-2009 11:17 AM
James - is it likely that now this will just continue indefinitely? I really don't know why it's happening. Although my downstream speed has had well-documented problems (SNR dropping to zero or thereabouts during the hours of darkness) the upstream connection hasn't had any problems at all - at least not that I could discern. SNR was always a rock-solid 5. But I fear that once the DLM decides to start banding, it won't stop.
Is there any way you can check on why my upstream line has been (re-)banded? Or do I have to go through the rigmarole of raising a fault ticket?
I did wonder briefly if I'd been put back onto ADSL Max, given that the trial has now ended. But it doesn't appear that trialists have been taken off the 21CN. If this is going to go on, though, I'm thinking I might as well take myself off the trial, move to Value and forget about higher speeds.
Graham
25-10-2009 5:07 PM
Quote from: Jameseh I'll drop them an email
Been away over the weekend but I'll hopefully be able to check the router again tomorrow morning. Any idea how long I'll have to wait for BT to pull their finger out and un-band the upstream?
Re:James - Can we uncap my upstream again please?
26-10-2009 9:20 AM
It certainly sounds like your upstream has been rebanded Is your router seeing a lot of errors still?
@ComplexP - It looks like that in a moment of sheer ineptitude, I managed to place your order incorrectly. I've placed it again and your upstream should be uncapped tomorrow.
26-10-2009 11:27 AM
Does that mean that my upstream isn't actually banded afterall?
