Is it possible?
- Re: Is it possible?
Re: Is it possible?
02-03-2012 2:32 PM
If so could you switch us over to the new higher speed connection and uncap the upload as well please?
Look forward to hearing from you,
Chris x
Re: Is it possible?
02-03-2012 4:17 PM
[quote=BT Availability Checker]Your exchange is planned to have ADSL2+ by 1st April 2012.
Looks like there's been some delay.
Jojo
Re: Is it possible?
02-03-2012 6:55 PM
The best way for you to keep an eye on things is to put your telephone number in to https://www.btwholesale.com/includes/adsl/main.html
Once that says you can get ADSL2+ post back on here and PN will upgrade you pretty quickly.
Re: Is it possible?
02-03-2012 10:01 PM
Oh well, fingers crossed it'll get done next month then 😃 Thank jojo
Chris x
adie:red removed inappropriate sentence
Re: Is it possible?
02-04-2012 6:24 PM
Re: Is it possible?
03-04-2012 11:00 AM
Wooo!!! I'll place to order for you.
Jojo
Re: Is it possible?
03-04-2012 11:18 AM
Re: Is it possible?
03-04-2012 8:26 PM
Once it's done, can i request that the upoad is uncapped? Sidenote, would that make the connection less stable?
Thanks x
Re: Is it possible?
04-04-2012 10:06 AM
Re: Is it possible?
12-04-2012 8:10 PM
The Ping is down at 15, fantastic, the upload is now 0.88 not 0.35, fantastic, but the download is still only cmoing in at 8 and not the 10-19 that you said it would, any reason for this?
Thanks, x
Re: Is it possible?
13-04-2012 10:01 AM
Re: Is it possible?
13-04-2012 3:03 PM
Download Speed
5.08 Mbps
0 Kbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 5.08 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.17 Mbps
Upload Speed
837 Kbps
0 Kbps 832 Kbps
Upload speed achieved during the test was - 837Kbps
Additional Information:
Upstream Rate IP profile on your line is - 832 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
We have identified that you have additional services enabled on you broadband line, please click continue to run advanced service tests.
This was the result of the test Jo 😃 x
Re: Is it possible?
13-04-2012 4:47 PM
Re: Is it possible?
13-04-2012 8:00 PM
Re: Is it possible?
16-04-2012 9:58 AM
I see you've not rebooted over the weekend. Will you let me know when you have?
Jojo
