@dave1240
I can see you've turned interleaving off via the control panel, that should take effect soon (if it hasn't already). The only other thing you can do really to improve speed would be to make sure the router's in the master socket and all other items plugged into the line are filtered as that'll minimise the interference you're getting from anything in your premises.
