Internet speed around 1/4 of usual
domfr202
For the past couple of days, my download speed has been around 1/4th of what it usually is, following the advice from another thread I checked the 'Downstream sync speed' on the status page of the router hub, and I can confirm that these numbers are also lower than the speed I should be getting.
5 REPLIES 5
Fixes: 334
Re: Internet speed around 1/4 of usual
@domfr202 A little more information would help other Community members help you. Welcome to the forums, BTW.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
If you can provide this detail, we may have a starting point. Any questions, feel free to ask.
domfr202
Product name,Plusnet Hub Two
Serial number,+108417+2147008164
Firmware version,v0.06.00.12134-PN (Tue Dec 14 10:24:54 2021)
Board version,R01
GUI version,1.6 19_10_2021
DSL uptime,0 days 1 Hours 7 Mins 26 Secs
Data rate,7.8 Mbps / 19.3 Mbps
Maximum Data rate,10.2 Mbps / 21.7 Mbps
Noise margin,8.9/6.4
Line attenuation,39.3/36.7
Signal attenuation,37.3/34.0
VLAN id,101
Upstream error control,Off
Downstream error control,Off
Data sent / received,80.5 MB Uploaded / 978.9 MB Downloaded
2.4 GHz wireless network name,PLUSNET-QKC2XJ
2.4 GHz wireless channel,Smart (Channel11)
5 GHz wireless network name,PLUSNET-QKC2XJ
5 GHz wireless channel,Smart (Channel36)
Wireless Security,WPA2 (Recommanded)
Wireless mode,Mode 1
Firewall,On
MAC address,C0:D7:AA:3A:0B:D0
Software variant,-
Boot loader, 0.1.7-PN (Thu Nov 30 09:45:22 2017)
https://imgur.com/a/QgQbVRC
Fixes: 334
@domfr202 Thanks for that data - I assume you are on the 80/20 (Fibre Extra) package? From what I can see, I strongly suspect there is a big problem somewhere in the BT/OR network causing you to lose the DSL connection. Did you check the phone line for noise, as that can also cause a similar occurrence?
domfr202
Yeah, I'm on the Fibre extra package. I can't check the phone line for noise as we don't have a landline.
Fixes: 334
You mean you don't have a phone - rather unfortunate, as a cheap corded handset is an essential tool for fault finding on ADSL/FTTC connection.
No major problem, but it would have helped. However, in light of what information we have, I suggest you report a broadband issue via: https://www.plus.net/help/report-a-problem/broadband/ .
Please let us know the result - which you should get sometime tomorrow morning.
