Internet keeps dropping out
moiragray
Past few days have been having internet problems. Been dropping out, I have went through all the checks, but its still happening, even tried the speed test and it wouldnt work?  When it drops laptop says connected but no internet?
Can you please help?
17 REPLIES 17
Fixes: 388
Re: Internet keeps dropping out
Welcome to the forums, @moiragray . As staff response is a little slow, lets see if the Community can help.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
Any questions, feel free to ask.
moiragray
Re "
For the Hub Two -
Navigate from the Home Screen to Advanced Settings > Technical Log > Information"
How do I find the Advanced Settings please?
Thanks.
Fixes: 388
see picture below:
moiragray
Screenshot 2022-11-15 13.59.51.pngScreenshot 2022-11-15 14.00.03.pngScreenshot 2022-11-15 14.01.09.pngScreenshot 2022-11-15 14.01.32.pngScreenshot 2022-11-15 14.27.07.pngScreenshot 2022-11-15 14.27.14.pngHi,
thanks, I found it. All screenshots attached.
Phone line was ok.
moiragray
Of course now im doing all this, the internet is spot on!
Fixes: 388
Thanks, Moira.
You are obviously a considerable distance from the green cabinet, with a long copper stretch, and the Tech log gives the best clues as to what is happening.
(1) Unless you are intentionally rebooting/switching off the Hub (which I doubt), there is a fault on the BB side of the network - your uptime shows that.
(2) The downstream u/s margin at 3.4dB won't be helping either on a line length as long as yours.
My suggestion is that you report a broadband fault via:https://www.plus.net/help/report-a-problem/broadband/
If you have any further questions, ask away.
moiragray
thanks for your help, will report fault.
Moira.
Fixes: 388
Let us know the outcome please.
TheMightyAJ
Fixes: 126
Hey @moiragray,
I'm really sorry to hear that you're experiencing issues with the connection at the moment. I've reviewed your account this afternoon and we haven't been able to detect any faults on the line at the moment - have you continued to experience these drops on your end? Also, have you had a chance to carry out any troubleshooting checks and if so, which ones?
 Alex H
Fixes: 388
@TheMightyAJ - IF the OP reported the issue via the auto-bot, what was the result - just out of interest?
moiragray
Everything seems ok today.  Probably be ok now for a while, then it starts over again.
thanks.
I did the following checks:
Fixes: 388
@moiragray Did you report it via the link I provided?
moiragray
All ok today, thanks.
Fixes: 388
If that was in reply to my post above - it did not answer it.
