Internet issue
pvmb
Fixes: 7
Internet issue
Internet contact failed abut 5 - 10 minutes ago where I am. Problem seems to be with Cloudflare DNS servers/network.
Had to revert PC's IPv4 DNS Server address to 'Automatic' and reboot. This seems to have cleared the problem. Either that or Cloudflare DNS problem was a temporary glitch.
6 REPLIES 6
pvmb
Fixes: 7
Re: Internet issue
Follow on from above. I seem unable to contact the Plusnet Gateway or DNS servers using ping (currently both working OK) - this is rather annoying, how would I test if they are contactable or not for test purposes?
The only one I am getting reliable ping returns from are Google DNS servers - still getting erratic returns from Cloudflare DNS.
Fixes: 334
Re: Internet issue
@pvmb It is possible/likely these servers are set not to respond to ping requests.
Fixes: 532
Re: Internet issue
@jab1 absolutely correct!. I don't think the gateways have ever responded to ping, and the PN DNS servers were modified some while ago not to.
pvmb
Fixes: 7
Re: Internet issue
...So we are rather stuck with random suck it and see when it comes to diagnosing any network issues?
Interestingly, I see a website I know that recently changed to being hosted via Cloudflare servers (Bot issues) is in trouble again this morning.
pvmb
Fixes: 7
Re: Internet issue
Cloudflare DNS Outage Disrupts Access for Thousands Globally
https://www.fixyanet.com/2025/07/cloudflare-dns-outage-disrupts-access.html
"So here’s something that caught a lot of people off guard recently — if your internet suddenly felt broken or certain websites stopped working for you, you weren’t alone. There was a major disruption caused by Cloudflare, and it’s been affecting thousands of users all over the globe."
Should be fixed now.
Fixes: 125
Re: Internet issue
if you are a Linux user take a look at the options traceroute provides.
There is also mtr (my trace route) with similar options.
both allow to traceroute using TCP or UDP
