Internet Sluggish For A Few Days
- Internet Sluggish For A Few Days
03-06-2014 5:45 PM
Hi, My internet's felt quite sluggish for a few days now.
Looking at my stats below from my limited understanding I think it should be ok? Just wondered if anyone more technically minded might see anything amiss?
Router Stats -
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 6 days, 05:35:55
Downstream: 21.07 Mbps
Upstream: 1.239 Mbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 2.6 dB / 6.1 dB
Line attenuation (Down/Up): 11.2 dB / 7.9 dB
Output power (Down/Up): 19.8 dBm / 12.4 dBm
FEC Events (Down/Up): 97034071 / 0
CRC Events (Down/Up): 393 / 116
HEC Events (Down/Up): 5650 / 160
Error Seconds (Local/Remote): 303 / 73
BT Speedtest Stats -
Download Speed 18.06
Upload speed 1.01
Ping Latency 32.88
Download speedachieved during the test was - 18.06 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 19.04 Mbps
Upload speed achieved during the test was - 1.01Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Router Stats -
ADSL Line Status
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Upload speed 1.01
Ping Latency 32.88
Message 1 of 6
(895 Views)
5 REPLIES 5
Re: Internet Sluggish For A Few Days
04-06-2014 11:27 AM
Hi woodm,
Have things started to improve now?
Message 2 of 6
(458 Views)
04-06-2014 12:06 PM
Chris - It does seem a bit better now now you come to mention it. Did something change?
Message 3 of 6
(458 Views)
04-06-2014 12:43 PM
I'm wondering if the sluggishness (I think is a word) may have been caused by the DNS issues we've had, which we rolled a fix out for, this morning.
Message 4 of 6
(458 Views)
04-06-2014 12:45 PM
Quite possibly. My browser seemed to be pausing for long periods of time looking up sites so that kind of fits.
Appreciate your response.
Message 5 of 6
(458 Views)
04-06-2014 12:46 PM
No problems. If you're interested in following updates on this, we've got a Service Status open here http://usertools.plus.net/status/archive/1401868720.htm
Message 6 of 6
(458 Views)
