Internet Connection Intermittent Drop Outs
DerekW
Re: Internet Connection Intermittent Drop Outs
Hi @Townman
Yes, they are
Primary DNS:  212:159.6.10
Secondary DNS:  212.159.6.9
"No one has ever become poor by giving" - Anne Frank
Fixes: 252
Same as mine.
I will add DNS monitoring to my "it would be interesting" to do list.  In the meantime, someone is following up on my question in the super user chat area.
DerekW
Hi @TheMightyAJ @Townman
Just a quick update as promised.
The change of DNS would appear to have resolved my issue.
Thank you for your help and input, it is much appreciated.
TheMightyAJ
Fixes: 126
I'm glad to hear that's done the trick! Just let us know if you run into any further issues and we'll be happy to pick this back up for review Smiley
 Alex H
Fixes: 252
Alex,
I've followed this up on the SU boards ... there is indeed something needing review.
duckettp
Im having a similar problem on my line that intermittently the devices on my network drop out, reporting DNS issues at various times of the day. This again has started around 3 weeks ago and has progressively got worse.
To clarify my networks has not be changed in over a year.
I have started a running a constant test this morning and has reported 4 outages already in 4 hours lasting up to a minute.
Something I have noticed is the latency starts to build before an outage and reminds me of a similar issue that I had when I was with BT.
Could someone from Plus net check the VLAN within the exchange for over provisioning i have a feeling that in my case with the latency increasing that the back haul network is at capacity and has started to drop network packets and as DNS packets are the first to be sent in most operation could cause problems.
For clarity i have always used googles DNS servers rather than plus net
TheMightyAJ
Fixes: 126
Hey @duckettp,
I'm sorry to hear that you've run into similar issues. I'm just running a test on your line and noticed that the test isn't recognizing your router - are you using a Plusnet Hub One or a 3rd party router that you've setup yourself?
 Alex H
duckettp
Yep I'm running a Draytek Vigor 130 Modem (BT SIN 498 compliant) in bridge mode terminating into a Unifi UDM pro to handle  PPPOE connection
The modem is showing a stable VDSL line at 79,999 and 20,000 with 9db SNR
But still getting:
11/03/2022 12:16:40 PM Online 0:59:19
11/03/2022 12:15:53 PM No Internet connection. Wi-Fi/Ethernet OK 0:00:47
11/03/2022 11:18:42 AM Online 0:57:11
11/03/2022 11:17:23 AM No Internet connection. Wi-Fi/Ethernet OK 0:01:19
11/03/2022 11:16:55 AM Online 0:00:28
11/03/2022 11:15:47 AM No Internet connection. Wi-Fi/Ethernet OK 0:01:08
11/03/2022 10:16:13 AM Online 0:59:34
11/03/2022 10:15:41 AM No Internet connection. Wi-Fi/Ethernet OK 0:00:32
11/03/2022 9:16:49 AM Online 0:58:52
TheMightyAJ
Fixes: 126
Thanks for confirming that @duckettp. Do you have our router to hand? If so, please could you try setting it up to see if there's any difference?
 Alex H
bobpullen
Fixes: 331
@duckettp @DerekW & @plustrev - how are things looking now?
There was some work carried out over the festive period and my personal monitoring looks much better now, displaying zero loss and decent round trip times for the Plusnet DNS resolvers.
DerekW
Hi Bob,
As I said earlier in the thread I changed the DNS on my router which resolved the issue for me.
I have not changed them back since.
Cheers,
Derek
bobpullen
Fixes: 331
@DerekW - well if you ever feel like changing them back, let me know how it goes. In theory, our DNS servers should be marginally quicker to respond (when working without issue!)
