Intermittent interference on phone line
- Re: Intermittent interference on phone line
09-02-2008 11:22 AM
Occasionally I get noise on the line which may only last for a period as short as 15 minutes but during that time a manual broadband resynch drops the upstream rate to as low as 192 kbps. Once the noise has stopped a resynch takes it back up to 448kbps with a noise margin of 20dB.
Watching my router logs I get an occasional resynch, which doesn't happen at any specific time, although it is more usual after dark, with the upstream noise margin dropping to 6dB or 7dB with low synch speeds.
It is fairly certain that something between my property and the exchange is causing interference in the lower frequency bands as the downstream speeds are relatively unaffected but given that it is very intermittent (once or twice a week is the normal frequency although I have run for two weeks without a problem).
The alternative, and perhaps easiest solution, is to get my default noise margin dropped to 12dB (it jumped from 9dB to 15dB because of a rapid series of power cuts) so that the resynchs don't drop my downstream speeds below 3,000 kbps.
09-02-2008 10:34 PM
11-02-2008 11:13 AM
11-02-2008 11:18 AM
You mention your upstream speeds dropping. Do you notice similar issues with downstream synchronisation speeds happening at the same time?
11-02-2008 11:53 AM
This part log is from before I changed to Vista 64 bit and the logging program wouldn't work
Just to add these are the current stats following a manual resynch 2 days ago to get the upstream speed up from 192 kbps
xDSL linestate up downstream: 3072 kbit/s, upstream: 448 kbit/s; output Power Down: 19.0 dBm, Up: 12.0 dBm;
line Attenuation Down: 50.0 dB, Up: 24.0 dB; snr Margin Down: 15.5 dB, Up: 20.0 dB)
xDSL linestate down
xDSL linestate up (downstream: 3008 kbit/s, upstream: 224 kbit/s; output Power Down: 19.0 dBm, Up: 12.0 dBm;
line Attenuation Down: 50.0 dB, Up: 24.5 dB; snr Margin Down: 15.5 dB, Up: 6.0 dB)
Quote Link Information
Uptime: 2 days, 0:49:49
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,648
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 24.0 / 50.0
SN Margin (Up/Down) [dB]: 15.0 / 9.0
11-02-2008 12:46 PM
I don't set how changing the target noise margin is going to help things as we don't have any way of setting a target upstream margin, which seems to be where your problem lies.
Have you done the usual filter and mdoem checks? Something could be dying somewhere.
11-02-2008 1:03 PM
Regarding the tests - This has been covered in two previous fault reports and tests which couldn't find anything wrong.
I think that I am answering my own question - I am going to have to live with it.
For reference these are the two previous questions ID: 21815749 ID: 23129505
11-02-2008 1:23 PM
11-02-2008 6:18 PM
11-02-2008 6:55 PM
Have you tried the BT automated test when you get the noise on the line. You just ring 151 and follow the instructions. Not sure if you can do the same when on Home Phone though.
11-02-2008 9:54 PM
