Intermittent Connection Drops
Dalekfish
Hi, for the past week I have been having intermittent internet drops that have been interrupting me working from home. I have tried texting help to 07800008121. But there is no answer or response. Can I request a line check and if possible the connection records for the past week for my property?
20 REPLIES 20
Fixes: 389
Re: Intermittent Connection Drops
@Dalekfish Welcome to the Community. When did you send the text - they are only responded to 0800-1930, in order?
Dalekfish
Hi I sent a few within working hours. 2pm on Monday and yesterday at 1pm.
Fixes: 389
Strange you haven't had a response, then. If you want help from the Community to try and resolve this, i have a script which will give other members a chance to see if we can see and sort it for you?
Staff response on here can be a tad slow at times.
Dalekfish
Hi, mate yeah that would be quite useful!
Fixes: 389
OK
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
Dalekfish
Dalekfish
Dalekfish
Hi, I am in the technical log of the Hub-2 and see no connection status section there?
Fixes: 389
@Dalekfish Thanks for those two pictures - although they are somewhat confusing - your Speed test suggests you are on the 80/20 package, and the 'observed speed' on the BTw checker suggests you are on the 40/10?
Fixes: 389
This is the screen I'm looking for:
Dalekfish
Dalekfish
I believe that I was upgraded possibly? I remember an email but cant find it for the life of me right now.
Fixes: 389
Thanks - and the Phone test? Looks to me like you are having xDSL drops. If the phone line is clear, can you post the current WAN tab from the Event log, just to confirm my suspicions, please.
Fixes: 389
Yeah - the detail in the Technical page confirms you are on 80/20.
