Intermittant Connection
- Re: Intermittant Connection
10-08-2007 9:49 AM
has anyone else had similar issues?
im not on an LLU exhancge as i opted out of it, im 15 metres from the exchange and on premier option 1
i dont normally have a problem with the connection, for example tuesday i downloaded 4.15gb of anime via http offpeak, for the following days i havent even been able to get above 200meg of xfer (with the exception of xbox live last night a demo ~800meg - stop start)
11-08-2007 9:00 PM
11-08-2007 9:34 PM
http://community.plus.net/forum/index.php?topic=467.0
may shed some light on your probs
11-08-2007 10:41 PM
Quote from: Tyreal74 for the past couple of days my internet connection has been very unstable, whenever i try to download a file by bit torrent or http even small files the connection just drops out, i cant even play xbox live on it.
Looks like the connection is losing sync, the support guys tried to run some testing this afternoon and left you a message, if you can get back to us we'll be able to re-run the tests.
Plusnet Technology
11-08-2007 10:47 PM
Quote from: matrix Hi there. Ever since we got broadband we are lucky to get one night a week when our connection is stable. The rest of the time you log on, and 5 seconds later the connection drops, it is impossibe to even get from one page to another without it dropping. I am glad I didnt cancel my dial up = it may be slow but at least you get on the internet. Plusnet have checked the line and say its ok, the next step is to get BT in = has anyone had BT in? I am loathed to do this at £150 a time? For info I only have the microfilter plugged directly into the main bt socket with nothing else - pt even the phone. I even turn off the tv in case it is leaking RF!!! Help.....
Looking at the connection logs for your connection it's showing that the connection is dropping every few minutes with the reason "user request". Normally that means that the router/modem disconnected the connection itself. I'd recommend checking the router for any idle timeout settings that could be causing the connection disconnect and if possible try a different router or modem to see if that makes any difference.
Plusnet Technology
11-08-2007 11:00 PM
Sorry if it is a silly question
12-08-2007 12:22 AM
To turn off any idle time out setting untick any check-box and/or set the value the zero (0).
12-08-2007 1:54 PM
12-08-2007 2:57 PM
I believe having two USB modems installed can be lead to problems, though don't have personal experience to back that statement up.
12-08-2007 3:31 PM
12-08-2007 4:23 PM
Plusnet Technology
12-08-2007 5:31 PM
13-08-2007 2:00 PM
ive been keeping an eye on the connection as much as possible,, i was having power outages on my router and ive now replaced it as of this morning
i still have the problems and i have never had auto disconnect on my router. it was the same router i was using for 18 months previously
ive informed plusnet support that the router is back online and powered up so im waiting on the tests to be run. hopefully itll be solved soon, i want my xbox gaming back ^^
