Interleaving & VoIP
- Re: Interleaving & VoIP
Interleaving & VoIP
25-01-2008 7:36 AM
Is there any relationship between interleave being on and sensible TCP pause time, I mean it looks like from time to time I have 100ms pauses?
Patrice
Patrice
Message 1 of 5
(1,093 Views)
4 REPLIES 4
25-01-2008 9:08 AM
Hi Patrice,
Whilst it shouldn't be causing that about of latency, I'm happy to put you onto a non interleaved line for 24 hours if you want to give that a go?
Message 2 of 5
(466 Views)
25-01-2008 10:04 AM
Yep, that would be fine: as you suspected, it's really for a trial. I can't discriminate why I have issues.
Do I need to raise a ticket or this post is OK?
Patrice
Patrice
Message 3 of 5
(466 Views)
25-01-2008 10:19 AM
Hi Patrice,
No need at all. I've put a ticket on your account to inform you that I have placed an order to remove interleaving from your line.
It will complete on Monday. If you want it readded, it will take a further 1 working day to do so.
Message 4 of 5
(466 Views)
25-01-2008 10:52 AM
Thanks.
Message 5 of 5
(466 Views)
