IP Profile change please
- Re: IP Profile change please
09-12-2010 5:16 PM
09-12-2010 5:21 PM
I've matched the PN profile to 2000 for you now.
Jojo
09-12-2010 8:59 PM
13-12-2010 3:46 PM
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :1728 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1750 Kbps
absolutely disgusting. been 4 weeks now, hasn't it.
13-12-2010 4:23 PM
do you have a test socket behind your master socket? Have you changed your set up since I did the SNR reset? Are you using any extension cables?
The sync rate is now 1728k so the profile will probably drop to 1500. After I performed the reset the line went down to 6dB SNR which is why the sync and profile went up. It's now gone up to 12dB so that's what has caused your sync rate to drop. I'll do anything I can to help but with a line of this length it can be said that it's operating within acceptable limits.
Jojo
13-12-2010 4:26 PM
(There's all sorts of factors at play, and it seems a bit daft of plus if they promised you'd get the same speeds as Tiscali!)
14-12-2010 9:11 PM
14-12-2010 9:30 PM
That is pretty close to the level at which you would get an IP Profile of 1750 which is triggered by a sync speed in the range 2016 kbps to 2240 kbps.
I would recommend that you should be aiming to stabilise on the 1750 IP Profile.
If you want to do better than that in your current house remember that the distance from the exchange is the most significant factor, so you may want to consider using a company such as this.
15-12-2010 8:29 AM
Quote from: jelv http://www.kitz.co.uk/adsl/max_speed_calc.php predicts a sync speed of 2336 for an attenuation of 61 and that would be with a 6db noise margin. This gives you an IP Profile of 2000. There is no way whatsoever you can expect to get any better than that.
Stay out of things that do not concern you. I WAS on a stable IP profile of 2500. You do not have all the facts.
I am now on
Download speedachieved during the test was - 1137 Kbps
Your DSL Connection Rate :1568 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1250 Kbps
after over 4 weeks of no-one giving a dam and actually trying to sort this out. This speed drop initially occured on November 16th, Its now December 15th and my profile continues to drop.
15-12-2010 9:22 AM
Quote from: DBB and its still plugged into the master socket.
Do you mean the front of the faceplate or the test socket?
Jojo
15-12-2010 9:35 AM
Quote from: DBB Stay out of things that do not concern you. I WAS on a stable IP profile of 2500. You do not have all the facts.
There is no need to be so rude to another forum member who does so much to help other Plusnet customers!
jelv is also trying to help you too!
15-12-2010 2:33 PM
15-12-2010 4:15 PM
Quote from: Joanne Do you mean the front of the faceplate or the test socket?
Test socket. and from what I can see thats another day where nothings been done.
15-12-2010 4:31 PM
I've just had a fault guy check for the latest from our suppliers and it looks like it will probably result in another engineer visit. Keep an eye on your ticket.
Jojo
15-12-2010 5:28 PM
I also hope the BT guy has plenty of time on his hands to wait for me to make it home as I can't take any more time off work for this.
This is not a problem at my end, and waiting since the 29th of November for plusnet to decide to send another bt engineer out, which is over 2 weeks since I stated the first visit failed, is disgusting and reeks of desperation, as the fault is not here.
