I thought I was with Plusnet.
Edward_Snowden
Why is it that what is my IP today (6th February 23) shows the following ?
Looks like; as usual, someone doesn't bother to to do correct name data entry when they use a new IP Block.
WHO the hell are BT Americas Inc. (A BT global services company serving USA and Canada !!!!!)
My Public IPv4 is: 150.143.36.134
My Public IPv6 is: Not Detected
My IP Location is: London, ENG GB
My ISP is: BT Americas Inc.
4 REPLIES 4
Fixes: 387
Re: I thought I was with Plusnet.
@Edward_Snowden You are still a Plusnet customer - BT in the UK have had a number of IP blocks  transferred to them from the States - as is obvious from the IP location data in your post. However, this data is not always fully corrected.
Where did you get that information from?
Edward_Snowden
Thank you for your rapid response John,
Data from where ?  My Router /PC and any ip and AS lookup site will show the info. BT Americas Inc. ??????? REALLY  ????Huh
What are 'not so savvy' Plusnet Customers supposed to think ?
The AS lookup clearly shows it is a  Plusnet.address block
My point was;  to show the incompetence (unable to do do the job they are being PAID to do !) of the person doing the data entry when registering / transferring the block to Plusnet.
Just another example of sloppy work practices these days in the UK in general.
I would have been SACKED if I did that, when configuring Networks in my past life.
NOT acceptable. Poor show.
Fixes: 387
@Edward_Snowden It is ISP location Service providers who are at fault - I checked your IP after posting my answer, and of the six referenced in my source, only one had  100%accurate information - although they all correctly identified the 'country'  location as 'UK'
Browni
Aspiring Hero
Fixes: 61
@Edward_Snowden  'not so savvy' users won't be doing an IP address lookup in the first place 😎
