I have just found out why my usage has increased
Oldjim
Resting Legend
Fixes: 63
I went to Sky News while the Bandwidth Monitor was running and if I go to a page with a video on it the site downloads the whole video even when it isn't running.
See this picture
10 REPLIES 10
Fixes: 1,484
Re: I have just found out why my usage has increased
all browsers or just firefox?
Oldjim
Resting Legend
Fixes: 63
Internet Explorer is the same
RPMozley
Fixes: 13
You should try "FlashBlock" that will hopefully stop it from downloading automatically and if you do want to see it, click the Flash place holder.
(Available for Firefox but nothing for IE)
That's RPM to you!!
pierre_pierre
havnt got the same monitor as you Jim
can you try these two BBC ones, the first doesnt seem to download till you play
http://www.bbc.co.uk/news/health-17384035
the second does
http://www.bbc.co.uk/news/uk-england-essex-17367843
Oldjim
Resting Legend
Fixes: 63
the second one just starts playing the first one doesn't start downloading but once started pausing it doesn't stop the feed
Oldjim
Resting Legend
Fixes: 63
Tried flashblock and they aren't affected
RPMozley
Fixes: 13
Hmm... Just check that FlashBlock is active. Can't remember if the default setting is on or not.
Anyway, I'll check things out later on the Sky News site, see what's going on for myself.
That's RPM to you!!
Oldjim
Resting Legend
Fixes: 63
Flashblock stops parts but not the bad ones
I have found the culprit - it is the Sky Media Player script so I have blocked it using Adblock Plus
jazz
As well as Adblock I use Ghostery - http://www.ghostery.com/ ;   This blocks all the things that follow you around - Google Analytics, Web Trends etc etc and also blocks those video clips that preload whether you want them or not!  Smiley
198kHz
Fixes: 41
Thanks for the tip, jazz. It's doing a great job with Firefox.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
