Hub two box flashing orange
Nichouse
Hello, I have tried all the recommended guidance available on the website to try to reconnect to broadband but the hub is still flashing orange and not connecting
6 REPLIES 6
Fixes: 353
Re: Hub two box flashing orange
@Nichouse I understood you had succeeded in connecting yesterday  - is this a recurrence?
Nichouse
This is the first time it's happened since we got the hub, which was about 2 months ago. Had some trouble setting it up but since it has been working fine
RealAleMadrid
Fixes: 67
Deleted
Nichouse
Yes, there was no issue with it yesterday
Fixes: 353
You are correct, @RealAleMadrid  - I misread the original post(s) date. Embarrassed
@Nichouse It sounds like you have lost connection somehow. This really needs Plusnet investigation, but unfortunately, it is a lonh weekend, and staff response is very thin at such times.
MatthewWheeler
Fixes: 503
Hi @Nichouse
I can see you spoke with us on the phone and all is okay now.
Let us know if you have any further issues
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
