Hub one
- Re: Hub one
Re: Hub one
28-08-2018 11:42 AM
Re: Hub one
28-08-2018 11:51 AM
Re: Hub one
28-08-2018 3:05 PM
Re: Hub one
28-08-2018 3:08 PM
Re: Hub one
28-08-2018 3:11 PM
Re: Hub one
28-08-2018 3:13 PM
Re: Hub one
28-08-2018 10:04 PM - edited 28-08-2018 10:09 PM
7.275.11 F2704N
Re: Hub one
28-08-2018 10:18 PM
Re: Hub one
28-08-2018 10:31 PM
Re: Hub one
28-08-2018 10:43 PM
Re: Hub one
28-08-2018 10:55 PM
Re: Hub one
29-08-2018 9:52 AM
Hi @Joe8, do you get similar results when you run wired tests with the routers? Or is it just Wireless speeds where you are seeing the difference?
Did you notice which wireless channel each router was connecting on at all?
Re: Hub one
29-08-2018 10:11 AM
Re: Hub one
29-08-2018 1:23 PM
Hi @Joe8
I have passed this over to our products team for you. They will investigate what could possibly be causing the drop in speed while using wired devices to the Hub 1 / 0 routers.
Re: Hub one
29-08-2018 3:05 PM
