Huawei HG612 Stats & Graphing Programs for VDSL2 (FTTC) Windows Users
- Huawei HG612 Stats & Graphing Programs for VDSL2 (...
- « Previous
- 1
- 2
- Next »
Re: Huawei HG612 Stats & Graphing Programs for VDSL2 (FTTC) Windows Users
10-03-2013 12:18 PM
Was not harvesting stats when having this issue.
Using Vista.
Had a quick look at the script and this is causing the problem here:
(snip) Plink -telnet -P 23 192.168.0.3
Changed the IP address to 192.168.1.1 and it's now working fine.
Regards
npr
10-03-2013 7:37 PM
@Bald_Eagle, perhaps this is something that could be added to the main program to once a day set the time/date and also when a resync is detected, rather than write a separate program for it. I'm always forgetting to set the time, and it often resets its self back to 2000
10-03-2013 10:37 PM
Quote from: Ronski @Bald_Eagle, perhaps this is something that could be added to the main program to once a day set the time/date and also when a resync is detected, rather than write a separate program for it. I'm always forgetting to set the time, and it often resets its self back to 2000
I might do both, to also cater for any users who wish to run things manually.
I also forget to reset the modem's time on occasions, which isn't a major problem if running the program(s) & schedules 24/7 as the log files confirm things.
e.g. from RESYNC.LOG:-
18/02/2013 06:12 - RESYNC detected (DS 26335 Kbps, US 5851 Kbps) since the previous ongoing data harvest (DS 26704 Kbps, US 5782 Kbps)
18/02/2013 16:45 - RESYNC detected (DS 25257 Kbps, US 5690 Kbps) since the previous ongoing data harvest (DS 26335 Kbps, US 5851 Kbps)
18/02/2013 16:52 - RESYNC detected (DS 25454 Kbps, US 5697 Kbps) since the previous ongoing data harvest (DS 25257 Kbps, US 5690 Kbps)
18/02/2013 17:21 - RESYNC detected (DS 25167 Kbps, US 5701 Kbps) since the previous ongoing data harvest (DS 25454 Kbps, US 5697 Kbps)
19/02/2013 06:38 - RESYNC detected (DS 25886 Kbps, US 5781 Kbps) since the previous ongoing data harvest (DS 25167 Kbps, US 5701 Kbps)
21/02/2013 06:39 - RESYNC detected (DS 25829 Kbps, US 5847 Kbps) since the previous ongoing data harvest (DS 25886 Kbps, US 5781 Kbps)
25/02/2013 07:53 - RESYNC detected (DS 26465 Kbps, US 5807 Kbps) since the previous ongoing data harvest (DS 25829 Kbps, US 5847 Kbps)
26/02/2013 18:47 - RESYNC detected (DS 25263 Kbps, US 5715 Kbps) since the previous ongoing data harvest (DS 26465 Kbps, US 5807 Kbps)
26/02/2013 23:47 - RESYNC detected (DS 25711 Kbps, US 5797 Kbps) since the previous ongoing data harvest (DS 25263 Kbps, US 5715 Kbps)
28/02/2013 05:49 - RESYNC detected (DS 26195 Kbps, US 5818 Kbps) since the previous ongoing data harvest (DS 25711 Kbps, US 5797 Kbps)
02/03/2013 02:49 - RESYNC detected (DS 25495 Kbps, US 5734 Kbps) since the previous ongoing data harvest (DS 26195 Kbps, US 5818 Kbps)
06/03/2013 16:47 - RESYNC detected (DS 25721 Kbps, US 5682 Kbps) since the previous ongoing data harvest (DS 25495 Kbps, US 5734 Kbps)
11-04-2013 1:13 PM
I found graph.sh but it obviously processes some data ... is there another script to collect the data?
I guess I need to find the "original scripts" (and original HOWTO ?)
11-04-2013 5:29 PM
You could try asking the question here:-
http://forum.kitz.co.uk/index.php/topic,12284.0.html
User burakkucat who wrote the original Linux scripts frequents that forum & he should be able to point you in the right direction.
Alternatively take a look here:-
http://drlforum.co.uk/showthread.php?tid=544
User alexatkin further developed the data harvesting & graphing scripts for Linux.
HTH.
22-05-2013 11:03 AM
I follow the links proved here and end up on this freewarefiles page ...
http://www.freewarefiles.com/downloads_counter.php?programid=84567
But all I see there is a sea of adverts and prominent "DOWNLOAD" buttons for s/w I don't want (and don't trust!)
Am I missing something there?
22-05-2013 11:17 AM
Clicking on : HG612 Modem Stats 1.0 at the top of the page takes you back to where you started
22-05-2013 11:27 AM
So, where to I download it?
dick:quote
22-05-2013 11:31 AM
22-05-2013 11:56 AM
You could try rs-w, it does the same thing and works well with the hg612.
http://www.s446074245.websitehome.co.uk/index.html
22-05-2013 12:12 PM
Quote from: Anotherone I'm sure Bald_Eagle1 will come and post the solution shortly.
Well, I don't have a solution (yet).
The links do appear to be broken at the moment.
I'll flag it, but I don't know how long it'll take to get fixed.
22-05-2013 1:29 PM
I've contacted support at Freeware Files, so hopefully the problem will soon be rectified.
22-05-2013 4:41 PM
22-05-2013 6:24 PM
Quote from: Ronski Thanks for bringing this to my attention, for some reason I hadn't received any email of posts on this thread, even though I'm supposed to be notified.
Cheers Ronski.
It seems to be fixed now
- « Previous
- 1
- 2
- Next »
