How to remove errors registered on my line
- How to remove errors registered on my line
- « Previous
- Next »
Re: How to remove errors registered on my line
04-07-2012 11:24 AM
Max: Upstream rate = 1068 Kbps, Downstream rate = 14972 Kbps
Path: 0, Upstream rate = 1107 Kbps, Downstream rate = 12387 Kbps
Link Power State: L0
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.5 5.4
Attn(dB): 32.0 18.0
Pwr(dBm): 0.0 12.7
ADSL2 framing
MSGc: 51 12
B: 220 33
M: 1 1
T: 2 4
R: 0 0
S: 0.5695 0.9749
L: 3104 279
D: 1 1
Counters
SF: 25313917 471992
SFErr: 24552 1054
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 22519 904
OCD: 2682 0
LCD: 0 0
Total Cells: 3415740805 1071676619
Data Cells: 208108574 30958849
Drop Cells: 79627
Bit Errors: 0 63406
ES: 20822 638
SES: 35 0
UAS: 34 34
AS: 410936
INP: 0.00 0.00
PER: 16.23 17.54
delay: 0.14 0.24
OR: 28.09 8.20
Bitswap: 3574 1002
Total time = 1 days 18 hours 9 min 42 sec
FEC: 0 0
CRC: 24552 0
ES: 20822 638
SES: 35 0
UAS: 34 34
LOS: 0 0
LOF: 0 0
Latest 15 minutes time = 9 min 42 sec
FEC: 0 0
CRC: 17 0
ES: 16 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 0 0
CRC: 22 0
ES: 22 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 18 hours 9 min 42 sec
FEC: 0 0
CRC: 1432 0
ES: 1303 89
SES: 1 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 0 0
CRC: 3642 0
ES: 2898 145
SES: 10 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Since Link time = 4 days 18 hours 8 min 55 sec
FEC: 0 0
CRC: 24552 1054
ES: 20822 638
SES: 35 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
04-07-2012 3:59 PM
There is one thing we haven't yet addressed with respect to downstream errors and that is the Current Line speed. If that is still 37Mbps it needs bringing into line with the BT IP profile.
Can you post the Current Line speed (Login required).
04-07-2012 6:05 PM
LURGAN
Estimated line speed:
6Mb (This may vary between 5Mb and 8Mb) - Checked on 2012-05-25 23:52:51
Current line speed:
37 Mb
04-07-2012 6:57 PM
Quote from: Anotherone There is one thing we haven't yet addressed with respect to downstream errors and that is the Current Line speed. If that is still 37Mbps it needs bringing into line with the BT IP profile.
It is still 37Mbps (see post above). But having it at that value brought down will not make any difference. There is no need for it to brought in-line with the BT IP profile.
04-07-2012 7:02 PM
04-07-2012 7:25 PM
04-07-2012 7:27 PM
Quote from: Anotherone Oh yes there is. If you try sending data at 3x what his line can cope with then some of it gets dropped - at random, and you get errors.
Incorrect. Since the IP profile is already set at the correct value, it prevents data travelling faster than it can travel. Therefore there are no problems.
04-07-2012 7:40 PM
http://community.plus.net/forum/index.php/topic,105726.16.html
If the Plusnet IP is set too high, then regardless of what the BT IP profile is set at, PN will indeed try sending data down the line too fast for what the line can cope with.
The result will be data dropped at the exchange equipment.
05-07-2012 8:35 AM
05-07-2012 2:57 PM
Hi Steek,
If you post the stats and we'll see what it's like in 48 hours.
05-07-2012 2:58 PM
[codeMax: Upstream rate = 1068 Kbps, Downstream rate = 14896 Kbps
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 6.4 5.4
Attn(dB): 32.0 18.0
Pwr(dBm): 0.0 12.7
ADSL2 framing
MSGc: 51 12
B: 220 33
M: 1 1
T: 2 4
R: 0 0
S: 0.5695 0.9749
L: 3104 279
D: 1 1
Counters
SF: 31427533 391210
SFErr: 28158 3802
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 25790 4935
OCD: 3080 0
LCD: 0 0
Total Cells: 2020299380 1330501328
Data Cells: 299259736 45896964
Drop Cells: 81842
Bit Errors: 0 335248
ES: 24188 1308
SES: 35 31
UAS: 34 34
AS: 510181
INP: 0.00 0.00
PER: 16.23 17.54
delay: 0.14 0.24
OR: 28.09 8.20
Bitswap: 4650 1277
Total time = 1 days 21 hours 43 min 47 sec
FEC: 0 0
CRC: 28158 0
ES: 24188 1308
SES: 35 31
UAS: 34 34
LOS: 0 0
LOF: 0 0
Latest 15 minutes time = 13 min 47 sec
FEC: 0 0
CRC: 16 0
ES: 16 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
FEC: 0 0
CRC: 15 0
ES: 14 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 21 hours 43 min 47 sec
FEC: 0 0
CRC: 3077 0
ES: 2869 251
SES: 0 11
UAS: 0 0
LOS: 0 0
LOF: 0 0
FEC: 0 0
CRC: 1961 0
ES: 1800 508
SES: 1 20
UAS: 0 0
LOS: 0 0
LOF: 0 0
Since Link time = 5 days 21 hours 43 min 1 sec
FEC: 0 0
CRC: 28158 3802
ES: 24188 1308
SES: 35 31
UAS: 0 0
LOS: 0 0
LOF: 0 0
- « Previous
- Next »
