How long to wait
- Re: How long to wait
How long to wait
11-08-2023 11:01 AM
Received the "Your fibre broadband ready to go" email and text at 7.12am.
11.00, router light has got no further than orange flashing (trued plugging into the openr3ach socket as well as normal phone sockets.)
Do I need to wait to midnight still, despite ahving received the above email?
Message 1 of 3
(1,021 Views)
2 REPLIES 2
11-08-2023 11:06 AM
@samnapper87 Your Hub should be plugged into the Master socket, either directly (if it is a filtered one), or via a 'dangly' filter if not.
It can take up to 23.59 of your 'go live' date for all the systems to line up, but is usually earlier.
12-08-2023 9:09 PM
Thanks for the advice re master socket, appreciate that 👍 Worked not long after I moved it through!
Message 3 of 3
(934 Views)
