How long for 135kbps?
- Re: How long for 135kbps?
09-03-2011 6:12 PM
Download Speed
46 Kbps
0 Kbps 250 Kbps
Max Achievable Speed
Download speedachieved during the test was - 46 Kbps
For your connection, the acceptable range of speedsis 100-250 Kbps.
Additional Information:
Your DSL Connection Rate :1647 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.16:35.7:52.58 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload Speed
351 Kbps
0 Kbps 443 Kbps
>Upload speed achieved during the test was - 351 Kbps
Upstream Rate IP profile on your line is - 443 Kbps
09-03-2011 6:30 PM
09-03-2011 6:45 PM
I rebooted my router just now and after connecting I get this:
Link Information
Uptime: 0 days, 0:00:45
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 2,387
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 35.5 / 55.5
SN Margin (Up/Down) [dB]: 16.0 / 12.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4,294,967,264 / 0
CRC Errors (Up/Down): 4,294,967,264 / 3
HEC Errors (Up/Down): 0 / 1
That seems like a huge number of errors, but only happens on connection and doesn't seem to increase.
09-03-2011 6:47 PM
Link Information
Uptime: 0 days, 0:05:19
SN Margin (Up/Down) [dB]: 16.5 / 13.0
CRC Errors (Up/Down): 4,294,967,264 / 10
HEC Errors (Up/Down): 0 / 7
So 4 billion errors in less than 40 seconds but 0 in 4 minutes.
09-03-2011 6:50 PM
Quote from: jayed I rebooted my router just now
Well that will have delayed you getting your normal speeds back!
Leave it on 24x7 and don't reboot it.
09-03-2011 7:04 PM
Uptime: 0 days, 0:22:06
SN Margin (Up/Down) [dB]: 17.0 / 13.0
Error Seconds (Local/Remote): 1 / 0
CRC Errors (Up/Down): 4,294,967,264 / 94
HEC Errors (Up/Down): 0 / 59
So still barely a change 20 minutes later but huuuuugggee amounts on connection.
09-03-2011 7:08 PM
09-03-2011 7:13 PM
and on other forums I've found in a google search. Looks to me like an error code of some sort.
09-03-2011 8:16 PM
10-03-2011 12:30 PM
Are you using extension cables/sockets at all? If you plug into the test socket? Let me know so I can run some checks for you.
Jojo
10-03-2011 3:55 PM
10-03-2011 4:37 PM
Hope that helps,
10-03-2011 4:50 PM
10-03-2011 4:57 PM
10-03-2011 5:14 PM
Definitely do that. I'll try to test that later form home and see what steps we should take next.
Jojo
