How about adding a nice error message to Plusnet DNS servers
- Re: How about adding a nice error message to Plusn...
- « Previous
- 1
- 2
- Next »
Re: How about adding a nice error message to Plusnet DNS servers
16-10-2008 12:05 AM
If DNS lookup succeeds then that is fine; application software can use the returned IP address for whatever purpose it wants.
If DNS lookup fails then that is fine too; application software can deal with the failure in whatever way it wants.
As already noted, browsers are not the only applications using DNS. Messing about with DNS for the "benefit" of browsers will likely break other applications in unexpected ways. Don't do it!
16-10-2008 6:59 AM
Quote from: linux Don't do it!
That would be my personal preference. I can't relly see the benefits for sch a thing unless we want to start using it for advertising revenue. I did use this Firefox add-on briefly once and thought it was useful until I realised that it clouded my judgement of what was actually happening when I did encounter problems.
16-10-2008 9:41 PM
As far as I understand it Linux, the page is only returned if the submitted request is an HTTP GET <domain>
18-10-2008 1:31 PM
Quote from: techguy As far as I understand it Linux, the page is only returned if the submitted request is an HTTP GET <domain>
So this has nothing to do with DNS?
18-10-2008 3:43 PM
18-10-2008 5:11 PM
Returning the address of a web server might be useful for browser applications, but it is useless (or worse) for other Internet applications.
A name error is a perfectly valid response by the DNS protocol and it is up to the application to decide how to react to it. It is not a "problem" that needs to be "solved" by ISPs.
My feeling is that unless PlusNet can foresee all the consequences of changing the behaviour of DNS in this way then they should not do it.
cp:quote
19-10-2008 7:40 PM
19-10-2008 8:41 PM
To get it to work you have to know to go to a particular part of their setup and list all her work's internal domains as per their support page here.
The support overhead for PN if they implemented a similar system would probably be quite large when VPNs stopped working!
Edit: corrected typo
21-10-2008 3:57 PM
Open source projects are great but some of the ideas are a little ill thought out I feel
- « Previous
- 1
- 2
- Next »
