House Move... Quoted speeds of 12mbps - 20mbps not near being hit.
- Re: House Move... Quoted speeds of 12mbps - 20mbps...
04-10-2011 11:52 PM
I noticed my broadband activated on Friday night, so I wonder is the slow speed down to the fact your meant to wait for like 10 days before it settles.
Even so, I was expecting it to be a hell of a lot faster than I am seeing so far. My connection is maxing out at 700Kbps which is aful when I was being told by several ISP's (Sky, Plus net, AAISP, BE) I should be expecting at least 12mbps down speed.
Would anyone expect this level of speed to kick in by the end of this week (10 days from first activation) or should I be raising a support call now to get it looked into.
Ugh with this pic resize... original readable link below
http://oi53.tinypic.com/20zxwlf.jpg
Re: House Move... Quoted speeds of 12mbps - 20mbps not near being hit.
05-10-2011 12:47 AM
What actual speed is possible is determined by your line conditions. What are the line stats from the router (SNR, Line attenuation etc)? ALso state what IP profile has been set on Plusnets side (on member centre-> connection settings-> High Speed Broadband)
05-10-2011 7:37 AM
The IP Profile is totally incorrect, I do not live in Walton anymore, i moved house thus why I did a house move with plus net which I was told was complete. Obviously not.
Postcode:
Phone exchange:
WALTON ON THAMES
Estimated line speed:
5Mb (This may vary between 3.5Mb and 7.5Mb) - Checked on 2011-01-29 02:11:33
Current line speed:
7.15 Mb
Router Stats
Channel: FAST, Upstream rate = 448 Kbps, Downstream rate = 8128 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Fast
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 11.3 24.0
Attn(dB): 16.5 12.0
Pwr(dBm): 19.8 11.9
Max(Kbps): 9408 1124
Rate (Kbps): 8128 448
G.dmt framing
K: 255(0) 15
R: 0 0
S: 1 1
D: 1 1
ADSL2 framing
MSGc: 1 1
B: 255 15
M: 1 1
T: 1 1
R: 0 0
S: 1.0000 1.0000
L: 2048 128
D: 1 1
Counters
SF: 2850879 2850923
SFErr(CRCErr): 4 0
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 1 0
OCD: 0 0
LCD: 0 0
Total Cells: 929064464 0
Data Cells: 183359673 0
Drop Cells: 0
Bit Errors: 0 0
ES: 4 0
SES: 0 0
UAS: 16 0
AS(Uptime): 48464
INP: 0.00 0.00
PER: 1.75 1.75
delay: 0.25 0.25
OR: 32.00 32.00
Bitswap: 0 0
Total uptime: 48464
Total time = 13 hours 28 min 23 sec
SF = 2850879
CRC = 4
LOS = 0
LOF = 0
ES = 4
Latest 1 day time = 13 hours 28 min 23 sec
SF = 2850879
CRC = 4
LOS = 0
LOF = 0
ES = 4
Latest 15 minutes time = 13 min 23 sec
SF = 47200
CRC = 1
LOS = 0
LOF = 0
ES = 1
Previous 15 minutes time = 15 min 0 sec
SF = 52982
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 1 day time = 0 sec
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
Showtime Drop Reason: 0
Last Retrain Reason: 0
dick:quote
05-10-2011 7:44 AM
Your router stats also confirm you are still on ADSL1 (G.DMT). The line stats also show you have more speed to come when you are moved to ADSL2+. If a Plusnet rep sees this they may be able to do the switch but it may not be possible yet if the 10 day trialling period is still in progress. You will just have to be paient and let things take their course.
05-10-2011 7:56 AM
05-10-2011 8:27 AM
05-10-2011 8:31 AM
Quote from: pierre_pierre what does BT say your line can support https://www.btwholesale.com/includes/adsl/main.html
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 11.5Mbps; typically the line speed would range between 10Mbps and 13Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1Mbps and downstream line speed of 11.5Mbps; typically the downstream speed would range between 10Mbps and 13Mbps.
05-10-2011 11:21 AM
It looks like the original order was rejected as it was placed incorrectly, sorry about that. I've now replaced the order for you and will check it later to confirm everything's alright, I'll update you then.
05-10-2011 11:38 AM
Can we check everything is as it should be now in case there was anything else missed. Just want to make sure anything that can help make it faster your end is done.
dick:quote
05-10-2011 1:45 PM
05-10-2011 8:07 PM
Is there much else plus net can do on their end regarding speeds if this isn't hitting the max it can?
05-10-2011 9:10 PM
Often improvements in the home wiring / set-up can be beneficial - things like removing the ring wire or fitting a filtered faceplate on your master socket can reduce line attenuation / improve SNR and thus achieve a better sync rate.
You can check if it is internal wiring slowing the connection by connecting the router to the test socket, which can be fund behind the lower user-removable panel on your master socket. This isolates any internal phones / wires and if you get a better sync then you need to look at your wiring.
05-10-2011 9:46 PM
The first thing I do when I move into any new house is remove the faceplate and get the router straight into the master socket.
Those SNR readings are from the router hooked into the master, so if you see any room for improvement from this please let me know (I can modify these settings from the router).
06-10-2011 11:15 AM
Just updating to confirm that the ADSL2 is due for the 14th
14-10-2011 7:43 PM
I heard this has failed again and is now pushed back to the 21st October!
I know members of support are watching it but who is responsible for these fails in the first place? Is it BT? No one is even telling me how/why they are failing.
It is truly is not acceptable.
