Help need a line test
Cornishrex11
Does Plusnet technical team read these posts? We are travelling in Asia for 6 weeks. We are relying on our internet at home to be working to check in on security cameras and for our automated wi fi catfeeder to work. It stopped working 48 hours ago - all kit saying the internet is offline. My aged 90 year father (aka internet illiterate), who is living there,  confirms that all the power is on, nothing tripped on the fuseboard, and the Plusnet router is lit up in pink as it should be (pass through mode to orbi house router). So either there is a line fault or the main orbi router is not working. I need Plusnet to do a line check. But I cannot text that number they advertise to ask for a line check because I do not have my registered phone with me in Asia (work phone - job wouldn’t let me take it away with me). Is there any way of having an email conversation with Plusnet to ask them to do a line check?
6 REPLIES 6
Fixes: 580
Re: Help need a line test
If that is the case, then it has DSL sync and there isnt a line problem.
Your problem sounds more like the orbi router isnt working.
Cornishrex11
Thanks. I’ll have to call my father to check again then as the orbi router has never gone wrong before, whereas plusnet, since we moved to it a few months ago, has gone offline a few times. So back to my question, do plusnet staff not monitor and respond to threads on this forum? Do I have no way of an email convo with them about double checking my line? There was a problem on the line only a month or so back so I am suspicious.
Fixes: 580
Staff do monitor this forum and respond, but don't expect an instant response. Bear in mind this is not an official support channel so it may take a while for a response.
198kHz
Fixes: 42
Welcome to the forum. 🙂
Unfortunately Plusnet send emails about promotions, upgrades etc, but do not use it for reporting or corresponding about faults or other customer issues.
BT technician (Retired)
@Cornishrex11
You can raise a fault using this link https://faults.plus.net
HTH
Cornishrex11
Thank you everyone.
