Have I been punished?
- Have I been punished?
07-11-2009 10:52 AM
I am not a leech, I hardly ever download big files, but one thing that is precious to me is my Pure Evoke Flow internet radio.
For some reason this keeps cutting out and yet it works fine at another location.
I can see nothing wrong with my wireless router so I am wondering such traffic has been "shaped" by plusnet into being unusable?
I get about 20 seconds of radio then no volume, wireless signal is at maximum.
No other devices using the internet.
My usage so far this month is just 9gb out of 16gb which must last till the 22nd. This is higher than usual as I have downloaded a few demos and a WEBEX training course for a piece of software I have to learn.
Just wondering if Plusnet has made any changes to to shaping as speedtest.net shows
If my traffic was being restricted is there a page on the member centre that can tell me?
Message 1 of 8
(1,610 Views)
7 REPLIES 7
Re: Have I been punished?
07-11-2009 10:57 AM
Please check what your current line speed is set at here: https://portal.plus.net/my.html?action=data_transfer_speed just in case your profile is low for some reason.
Call me 'w23'
Message 2 of 8
(608 Views)
07-11-2009 10:59 AM
Thanks for reply, Link says it is fine:
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
7000
Current line speed:
7000
Message 3 of 8
(608 Views)
07-11-2009 11:49 AM
as you did not tell us your package and times have a look here http://www.kitz.co.uk/isp/plusnet_shaping.htm
Message 4 of 8
(608 Views)
07-11-2009 4:21 PM
Surely your internet radio uses streaming traffic? This should run at line speed on all packages at all times, shouldn't it?
Message 5 of 8
(608 Views)
07-11-2009 4:26 PM
Unless it's BB+ which doesn't prioritise streaming traffic, though not sure what PN package has ever had a 16GB cap.
Message 6 of 8
(608 Views)
07-11-2009 4:29 PM
Presumably that 16GB includes some paid-for top-up?
Message 7 of 8
(608 Views)
Re:Have I been punished?
09-11-2009 10:32 AM
Hi Zap,
In this case I'd recommend a wireshark capture - if you follow the guide but instead of downloading the file start your radio stream instead, that will capture the packets from the radio stream. You'll then be able to see what priority they're assigned, and if it's not in gold submit a ticket with the wireshark pcap file attached. We'll be able to make sure that it gets added for you.
Hope that helps,
Hope that helps,
Message 8 of 8
(608 Views)
