Had problems since before Xmas with Broadband connected but random no internet. Anyone help please?
- Had problems since before Xmas with Broadband conn...
Re: Had problems since before Xmas with Broadband connected but random no internet. Anyone help plea
10-06-2021 10:32 AM
10-06-2021 10:56 AM - edited 10-06-2021 10:57 AM
I trust that you are using the BTHH5a version, in which case there is next to nothing to configure, beyond providing the password!!
I sample at 10 second intervals, plot 720 points per graph (which delivers 2 hours) and capture everything.
A 10 second sample rate offers adequate granularity to capture short duration noise spikes. The SNRM graph is the only one we are particularly interested in.
10-06-2021 11:12 AM - edited 10-06-2021 11:26 AM
10-06-2021 11:28 AM
Hi Rob,
That is not looking pretty! Need to watch that and see if you can correlate the "disturbances" with anything happening in the household.
11-06-2021 8:25 AM
After switching pc on at about 0640 today. Quite a drop. Capture attached.
Only other things on are fridge and a freezer. Tv/recorder unplugged, as is second pc, printer and phone base. I have previously done tests with just laptop on battery monitoring the previous router s/n and everything I am aware of unplugged. Then, it made no difference. When the OR guy was here, noise on a MW radio increased out in the street. No DF was possible though to locate it. Despite this drop in noise margin, the attenuation and speed are both unchanged from yesterday.
Rob
11-06-2021 8:36 AM
Thanks for getting back to us Rob.
Just tested your line (sorry for the extended drop) and looking at RRT data, there are no issues flagged but I can see your upload speed's increased and download speed's dropped by a tad.
I'd recommend keeping an eye on things with routerstats and let us know how it goes.
11-06-2021 8:55 AM
11-06-2021 10:17 AM - edited 11-06-2021 10:21 AM
Rob
It would be more helpful if the monitoring were run 24x7.
Something happened overnight which we do not have a view on, which we need to capture to understand what is happening. I would not expect the attenuation to change. I have difficulty taking your statement on sync speed (ignore max rate speed) as stated. With that change in SNRM I would expect to see an improvement in line sync speed and thus suspect that the line dropped over night.
However if the line had dropped, I would have expected the SNRM to have been 9dB or 6dB - the current plot is not at either of these values, so something does not look right!
The post test resync shows a massively increased SNRM again. When posting the noise margin over a resync, it would be helpful to also see the sync speed graph as well please. What is the attenuation on the line please?
@Gandalf is this line banded please?
Re: Had problems since before Xmas with Broadband connected but random no internet. Anyone help p...
11-06-2021 11:05 AM
I've just run a quick check on the line and can confirm that it is not banded. The SNRM is coming through at 9dB which is expected given the loop loss on the line.
Broadband profile - WBC 160K - 24M Medium delay (INP 1) 9dB Downstream, UC Medium delay (INP 2) 9dB Upstream (ADSL2+)
11-06-2021 11:25 AM - edited 11-06-2021 11:30 AM
I will leave pc on overnight then.
From my current Helpdesk page
6. Data rate:828 / 7256
7. Maximum data rate:21215 / 7576
8. Noise margin:10.5 / 9.8
9. Line attenuation:21.8 / 42.0
10. Signal attenuation:21.8 / 40.4
11. Data sent/received:292.6 MB / 2.6 GB
Looking back at my saved log pages from starting yesterday morning, the only change I can see from then to now is d/l speed has increased from 7218 to 7263, as printed along top of the page.
NO drops at all.
Thanks, Rob
11-06-2021 1:23 PM - edited 11-06-2021 1:25 PM
42dB does not seem too untoward so a 9dB SNRM is a little surprising. Accepting that the SNRM is 9dB this line is performing right on the nail. So the big question is what is driving the 9dB target on a moderate attenuated line?
I suspect REIN, which hopefully 24x7 monitoring might illuminate!
Note the max rate US figure is very suspect makes one wonder about the behaviour of the router!!
Just to cover the bases, regular QLTs might be helpful here, especially if you see the SNRM shifting around.
11-06-2021 3:54 PM
"Note the max rate US figure is very suspect makes one wonder about the behaviour of the router!!"
Could it be a failing of the routerstats thinking my router is a BT branded one, some difference maybe? However, when monitoring Connection Speed the graph is 0 - 1100 US. 0 - 8000 DS.
QLT have all been ok..... so far. Will continue to monitor, especially if I see disturbance on the graph.
Been reading up on REIN and SHINE as well:
https://kitz.co.uk/adsl/rein.htm
Some interesting reading, with a lot of terms I am familiar with in my lifetime associated with radio communication. I wouldn't mind borrowing one of those BT/OR 444B RF testers! A lot smaller than my mains powered HP spectrum analyser.
Thanks for assistance,
Rob
11-06-2021 4:36 PM
Rob
Hi Rob,
No.
I am referring to line 7 in post #115 where you posted the line stats reported by the router itself. The DS max rate figure is similar to the actual DS sync speed, however the US max rate figure is one which anyone on FTTC 80/20 would be delighted with and is beyond the bounds of physics on ADSL.
11-06-2021 5:58 PM
12-06-2021 7:58 AM - edited 12-06-2021 8:01 AM
