Gateway graphs
paulgul
Gateway graphs
Has something gone wrong with the gateway graphs - the first two are completely blank, whilst the others show hardly any dropped packets - but usenet speed is very slow. Also tried to check which gateway I was on and it just showed 'unknown gateway'
Paul
11 REPLIES 11
James
Re: Gateway graphs
Hi Paul,
This will be related to the work we did the other night.
It's something that we are aware of.
paulgul
Re: Gateway graphs
Quote from: Jameseh
Thanks James - any Idea why usenet speed is very slow at the moment?
Paul
Chris
Legend
Fixes: 169
Re: Gateway graphs
Customers establishing new connections to the Internet whilst the platform is offline will be assigned a default traffic management profile. This may result in slower than expected performance on lesser priority traffic such as Peer-2-Peer and Binary Usenet.
If you connected during the maintenance then you might be affected by the info above. A simple reboot of your modem/router should fix it.
Chris
Legend
Fixes: 169
Re: Gateway graphs
That quote was from this:-
Planned Ellacoya Maintenance
paulgul
Re: Gateway graphs
Thanks Chris, I'll try re-booting
Paul
Chris
Legend
Fixes: 169
Re: Gateway graphs
Might be worth powering down for 10 minutes or so, just to make sure the previous session ends correctly.
bobpullen
Fixes: 316
Re: Gateway graphs
Paul, can I ask what account type you have?
paulgul
Re: Gateway graphs
Quote from: Bob
Sorry, only just read your question - account is Option 4
Paul
bobpullen
Fixes: 316
Re: Gateway graphs
Thanks, I think it /might/ be related to Broadband Premier traffic on the network. If you look here you'll see that we squeeze Premier P2P at midday. Before this it's a bit of a free-for-all and I'm wondering if this is why you were seeing the low speeds before midday. I'd be interested to know how things were early afternoon that day?
paulgul
Re: Gateway graphs
Hi Bob,
First, the link you gave on the word 'here' doesn't seem to work.
As I mentioned in another thread, the speed from around 11am to the 4pm watershed were very poor - from memory around 10-15 Kb/s. Before 11am the speed seemed fine although I can't give exact figures - I only tend to look at figures when there are problems.
Paul
James
Re: Gateway graphs
Paul,
bob meant this one:
http//www.plus.net/support/broadband/products/archive/bb_premier1.shtml
