Gateway graphs
- Re: Gateway graphs
Gateway graphs
25-10-2007 11:53 AM
Paul
Re: Gateway graphs
25-10-2007 11:55 AM
This will be related to the work we did the other night.
It's something that we are aware of.
Re: Gateway graphs
25-10-2007 11:57 AM
Quote from: Jameseh
Thanks James - any Idea why usenet speed is very slow at the moment?
Paul
Re: Gateway graphs
25-10-2007 12:01 PM
Quote Customers establishing new connections to the Internet whilst the platform is offline will be assigned a default traffic management profile. This may result in slower than expected performance on lesser priority traffic such as Peer-2-Peer and Binary Usenet.
If you connected during the maintenance then you might be affected by the info above. A simple reboot of your modem/router should fix it.
Re: Gateway graphs
25-10-2007 12:03 PM
Planned Ellacoya Maintenance
Re: Gateway graphs
25-10-2007 12:04 PM
Paul
Re: Gateway graphs
25-10-2007 12:05 PM
Re: Gateway graphs
25-10-2007 6:08 PM
Re: Gateway graphs
26-10-2007 1:22 PM
Quote from: Bob Paul, can I ask what account type you have?
Sorry, only just read your question - account is Option 4
Paul
Re: Gateway graphs
26-10-2007 1:59 PM
Re: Gateway graphs
26-10-2007 2:09 PM
First, the link you gave on the word 'here' doesn't seem to work.
As I mentioned in another thread, the speed from around 11am to the 4pm watershed were very poor - from memory around 10-15 Kb/s. Before 11am the speed seemed fine although I can't give exact figures - I only tend to look at figures when there are problems.
Paul
Re: Gateway graphs
26-10-2007 3:19 PM
bob meant this one:
http//www.plus.net/support/broadband/products/archive/bb_premier1.shtml
