Gaming problems, is it down to my Internet or is it down to the 2704n router
- Re: Gaming problems, is it down to my Internet or ...
Re: Gaming problems, is it down to my Internet or is it down to the 2704n router
16-03-2016 12:09 PM
I my experience all the engineers I have met are skilled and knowledgeable enought to fix either or both phone or broadband issues on the same visit ,and usualy do . They are by and large all very well trained and motivated . Sometimes they lack the background information they need prior to attending a fault for which they inevitably blame Plus Net for not sending it through, although they can ring PN to fnd out information befofre or druting the visit .
Engineers they have told me there is no such thing as a specilaist broadband engineer or a phone engineer , some are more expeirneced and have been trained to a more technical level but they should all be able to fix any obvious issue they are sent to deal with. If they can't then there are internal BT Technical Advice lines they can call. Or they can arange for a more senior , experinced engineer to attend.
Occasionally there has been a total misundertabding of the reason for a fault and a lot of time has been wasted. I have written about these farcical goings on before but has always been when BTOR systems have totally failed to pass on the necessary details to the engineers .
16-03-2016 12:12 PM
16-03-2016 12:17 PM
16-03-2016 12:31 PM
Quote Even when I explained to the engineer the problems he never once offered to phone plusnet to confirm just stated he wasn't allowed to do anything else
Well that can't be true : That engineer was not being honest . I have experienced that happen many times to check on varius natters . I guess in situations where the engineers are overworked, and badly managed they could adopt a jobsworth approach , but from my expereince, that's rarely been the case: However what I always do is advise customers to have their phone and Internet provided by the same provider as if they do not , then this is a perfect excuse for one to blame the other.
16-03-2016 12:53 PM
Hopefully I get more out of the next engineer visit and they find the fault.
16-03-2016 3:06 PM
16-03-2016 9:04 PM
Quote from: gpsmout Engineers they have told me there is no such thing as a specilaist broadband engineer or a phone engineer ................
Then in that case you haven't been told correctly. There are specialist broadband engineers. And, not all engineers are trained in broadband either.
The phone line is the responsibility of Openreach, standard broadband is the responsibility of BT Wholesale. If a phone line fault has been found or suspected that the CP/ISP will request Openreach to attend to test and resolve any faults. The engineer is not tasked to deal with any broadband faults or go to the exchange and mess around with broadband equipment - indeed they are not allow to.
A lot of broadband issues are because of a faulty phone line, and where the confusion comes about is on two counts - 1) The end user doesn't appreciate that fact, nor has it been explained to them and 2) if all they do is complain about a broadband fault and the engineer that Openreach send cannot detect any phone line fault, then it will be passed back to the ISP.
Harry is quite right in what he is saying
Quote from: HarryB Looking over your fault ticket, I can see you've advised you're experiencing no dial tone intermittently. If this is the case, this could be causing your broadband problems, however I don't believe a broadband fault would cause no dial tone.
When the engineer comes, it's best to stick with having them investigate why you are experiencing no dial tone intermittently and not mention anything about broadband as they may then fob you off without investigating the intermittent phone fault which could well be causing your broadband problems.
@Alex
As Harry has said, stick to going on about your intermittent Dial Tone and the other problems with calls. This is likely caused by a bad joint or cable fault somewhere and may not be easily tracked down, but if you get a decent engineer they will hopefully check the most obvious things if they don't immediately detect a fault.
There are some "jobsworth" engineers about (as mentioned by gpsmount) but they are usually quite rare, but at the same time they do not have all the freedom to use as much of the initiative as they may have.
The exception to all the above is when the ISP has booked an SFI engineer, usually when an ongoing fault is proving troublesome to resolve. Those engineers should have the ISP's instructions passed to them and are (usually) given a 2hr slot to investigate and resolve/determine the action needed to resolve the fault and will usually liaise with the ISP when requested by the ISP.
The advantage of having your phone service and broadband service with the same company is that when you have an issue, even when you don't understand the complications, you shouldn't get passed from pillar to post.
18-03-2016 8:20 PM
19-03-2016 9:48 AM
If Harry is about maybe he'll be able to throw some light on it as well.
19-03-2016 1:59 PM
20-03-2016 9:38 PM
20-03-2016 9:55 PM
Anyway I hope you are well
21-03-2016 12:13 PM
21-03-2016 1:15 PM
Anyway still noreply to my ticket I thought someone would have answered in the forums by now. Sad thing is when I was with talk talk before I left they increased something called a profile (unsure what that was) and I was getting 20mb download speeds I only left them because the cost was astronomical at the end of contract. And to top that off virgin are offering 50mb fibre optic broadband and line rental for the same price iam paying plusnet at the moment for adsl 12 month contract which after 12 months goes up to just over £30.
21-03-2016 2:02 PM
