Game priority over Netflix streaming
aniboi
Is there a way to prioritise network traffic for my game instead of netflix streaming? Whenever I'm on counterstrike my girlfriend streams netflix and my ping spikes from 10-20 all the way to 100+ and it becomes unplayable. I don't want to make her have to stop streaming whenever I'm playing games. It happens on netflix but not youtube, that only goes to like 30 and it's more playable.
Can I not access QoS priority to throttle the traffic to netflix and prioritise my PC?
If it helps, my PC is on a wired connection while she is on wifi either from the TV or from her laptop
2 REPLIES 2
RichardB
Seasoned Champion
Fixes: 39
Re: Game priority over Netflix streaming
Hi @aniboi,
My experience on FTTC and FTTP is that applying QoS to the only upstream prevents the ping spiking when others are streaming.
I do not have to priortise one device above another or apppy QoS to tne downstream.
I am not a yamer but use QoS to make sure Teams and like work smoothly when working from home.
To implement QoS I use my own router running OpenWRT.
I do not use the Plusnet supplied router. It is in the cupboard as an spare in case my main router fails.
Regards
Richard
Fixes: 479
@aniboi
There is no QoS setting capability on the Hub 2. There is nothing to stop you buying a third party combined modem/router (I assume that you are on FTTC). The settings are here: https://www.plus.net/help/broadband/broadband-connection-settings/
