G.992.5 request :)
- Re: G.992.5 request :)
05-07-2012 1:02 PM
05-07-2012 2:25 PM
Noticed another system ticket #136980857 Is this just part of the CCSNR ?
Thx choo
05-07-2012 2:55 PM
05-07-2012 3:06 PM
So the all being well it should be 6db SNR up/down with Interleave depth 1 or 2.
05-07-2012 3:21 PM
05-07-2012 6:23 PM
Quote from: Joanne @choo
Bless you!
Lots of people sneezing on this thread - hay fever?
05-07-2012 6:31 PM
Its still at 15db and these thunder storms wont help
06-07-2012 10:38 AM
06-07-2012 1:22 PM
Downside is it still looks like the DLM is up at 15db and now the bRAS TFT101 do not seem to be working.
The Service ID is: ************947
This is a 21CN line.
The current Downstream BRAS rate is: 4.04 Mbps
The current Upstream BRAS rate is: 0.83 Mbps
Current line speed:
3.2 Mb
Thanks choo
06-07-2012 1:41 PM
06-07-2012 1:43 PM
Can you provide the Tone numbers for those first 4 gaps and any Vendor information for the router and MSAN chipsets?
cheers
Graham
06-07-2012 2:07 PM
@GrahamC
06-07-2012 4:31 PM
It seems that your line shows the same quirks as a number of others regarding certain tones as discussed here.
cheers
Graham
06-07-2012 6:03 PM
I see the first 3 tones with no bits allocated match those tones missing in the ADSL1 & ADSL2 modes identified by Graham. What's causing the remaining 10 tones to be compromised is an interesting question (other than the one that is a broadcast station).
09-07-2012 12:24 PM
If fixed profiles are not an option any more , can the the line be set so it doesn't reach an Indicative Line Quality of RED ?
Thanks choo
