Frequent disconnections
- Frequent disconnections
on
26-01-2020
10:15 PM
- last edited on
27-01-2020
8:21 AM
by
Moderators Note: Personal information removed
Re: Frequent disconnections
27-01-2020 2:52 PM
Hi @Dan353, welcome to the forum.
I can see see the frequent disconnections on your broadband connection but it has been fairly stable with no disconnections in the past 5 days however, tt looks like the signal strength for your line is set too low which explains the frequent disconnections that you are having. I have placed an order to up your signal strength which should complete in the next hour. If you then turn the router off and then on again in a hour or later the connection should be back to normal for you.
