Flashing red
Laurad18d
Flashing red
My internet is flashing red and I have no internet. Please how can I fix this quickly?
Tags (1)
2 REPLIES 2
Fixes: 384
Re: Flashing red
@Laurad18d Try rebooting the Hub - hold a paper clip or similar in the reset hole until the light turns green, release and wait until it goes blue.
If that doesn't work:-
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
MatthewWheeler
Fixes: 503
Re: Flashing red
Hi @Laurad18d
I can see our support team has been contacted and a engineer has been booked for tomorrow
If you're still having issues after the visit let us know
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
