Flashing Orange Light on Router
Airbornecon
Re: Flashing Orange Light on Router
Hi, yes two sockets
Fixes: 585
and is the router is connected directly to the DSL socket ?
Airbornecon
Apologies! It’s one socket and we are using the filter
Fixes: 585
Are you sure that is the Master socket ?
If there is a filtered master socket elsewhere and the socket you are using is an extension, then there will be no broadband signal at that socket
Is there someone at home who could take a photo of the socket, we could probably determine if its the master
For information, the current single port Openreach master socket looks like this https://www.amazon.co.uk/OpenReach-Telephone-Master-Machine-included/dp/B07HVDCJKS/ref=asc_df_B07HVD...
Airbornecon
Hello everyone, this was 100% a case of me being an idiot.
I was using the filter when in fact I had two sockets, one for open reach fibre and the other for the phone line.
Apologies for wasting everyones time!
RobPN
Fixes: 15
@Airbornecon
At least you had the integrity to admit your mistake! Thumbs_Up
Airbornecon
Sometimes it’s best to own your mistakes!! And i was genuinely thankful people were trying to help me too!
JordanTA
Hi there
Aware this isn't an active thread for discussion, but it has been flagged as getting a decent volume of views. So just in case any new viewers are having problems with their Hub lights, please have a look at our hubs lights page here.
Hopefully will help.
