First Socket No Improvement
- First Socket No Improvement
26-04-2011 12:47 PM
Farthest from spur (11:30am) everything connected as normal
Uptime: 0 days, 2:24:25
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3,072
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 23.0 / 42.5
SN Margin (Up/Down) [dB]: 24.5 / 13.5
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 3 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 189
HEC Errors (Up/Down): 0 / 163
Nearest to spur (8:30am) with only filter and router connected
Uptime: 0 days, 0:03:11
DSL Type: G.992.3 annex A
Line Attenuation (Up/Down) [dB]: 23.0 / 39.5
SN Margin (Up/Down) [dB]: 25.0 / 8.5
Error Seconds (Local/Remote): 2 / 0
CRC Errors (Up/Down): 0 / 80
HEC Errors (Up/Down): 0 / 20
I had the cabling etc ready to go but there isn't much point in moving the router looking at those figures.
Re: First Socket No Improvement
26-04-2011 2:09 PM
So swapping sockets often has minimal effect.
Have you also removed the ring wire as advised by Kitz etc.?
26-04-2011 2:24 PM
26-04-2011 3:05 PM
26-04-2011 6:53 PM
Am I stuck with bell wire problems, errors, disconnections, dropping speed, unless I pay BT to change it?
26-04-2011 7:04 PM
The first stats (Farthest from spur) are significantly better.
26-04-2011 9:07 PM
26-04-2011 10:25 PM
Quote from: billnotben I can't really touch it can I?
Well you might need to take it off the wall to decorate, and some wires might accidentally fall out.
(as long 2 and 5 stay in you should be OK)
And if you have a telephone fault the BT engineer will probably fit a modern master as part of the fix.........
27-04-2011 2:30 PM
Quote from: HPsauce Well you might need to take it off the wall to decorate, and some wires might accidentally fall out.
It's looking dirty around that plug. With my vacuum cleaner set to turbo maybe the ring wire will get sucked off.
27-04-2011 4:49 PM
Am I the only one that noticed the Sky extension plug before the filter? Needs to be the other way around. Filter first with sky extension plugged into that.
Jojo
27-04-2011 5:23 PM
I assume that's right?
We're a Sky free house.
27-04-2011 5:27 PM
27-04-2011 6:11 PM
Quote from: jelv As it is the extension lead could be picking up interference which because it's before the filter for the router could be causing problems.
I'd bet on will not could.
t'other way round is correct as stated above.
27-04-2011 7:21 PM
The BT line only has 2 incoming wires so anything else is the customer property i.e the ring wire
Puddy
27-04-2011 7:41 PM
Quote from: puddy otherwise how could you wire in any extensions?
Well, thinking back to the "old days" I believe "you" were only allowed to use plug-in extension wiring with such sockets.
Hard-wired old-style extensions should have only been added by BT engineers.
In fact I have in my posession a British Telecom booklet (PHME 2137/6/89) that explains that it became legal on 1st December 1986 to add your own extensions provided that you used "approved" kits.
This shows clearly that for newer (NTE5A style) master sockets you access the back of the removeable faceplate, but that for older ones you MUST use a plug-in adapter.
Not sure if anything much has changed since then......
