Plusnet speed stuck
woodsider
Plusnet speed stuck
DSL line sync rate is 7616k. Plusnet speed is 3.5M.
Like that since 14 April, apart from a couple of bery brief coughs in the line, probably due to the mains electrical supply here.
Any chance of raising Plusnet speed?
jojopillo
Re: Plusnet speed stuck
Hi woodsider,
I've changed it to 6500 to match the BT profile so you should see that within the next 15 minutes.
Jojo Smiley
woodsider
Yep! Done. Thanks.
