File 192.168.1.254/expert_user.html
Rfa
Does anyone know where I can find this file as it seems to be unavailable on the internet ?
Alternatively can someone suggest how to turn DHCP on in a Sagecom 2704N router without the file ?
I turned it off to make the router a switch but need to turn it back on again.
Rfa
1 REPLY 1
Fixes: 390
Re: File 192.168.1.254/expert_user.html
If you want to use it as a modem/router again simply push a paperclip or similar into the factory reset hole and keep the swtch closed for 20 seconds. Then leave it and it will reset to the same condition as when supplied. Note it will take several minutes to bring you back on line.
Alternatively just enter 192.168.1.254/expert_user.html into the address field , not the search field of a browser. If it doesn't work try a different browser.
