Fibre not reaching minimum speed
Fixes: 475
Re: Fibre not reaching minimum speed
These results show you synching at 77k+ Mbps. This suggests that you have a WiFi problem. Keeping switching is off is likely to introduce more speed problems. Try changing the wireless channel.
Snarf
Thanks all. I'll take a look at a WiFi analyser and see if anything is interfering.
Interestingly now (without rebooting) I'm suddenly getting 60-70Mbps!
