Faulty router replaced - what now?
- Re: Faulty router replaced - what now?
19-12-2010 9:40 AM
19-12-2010 9:50 AM
19-12-2010 10:00 AM
19-12-2010 10:40 AM
Uptime: 0 days, 20:55:49
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,036 / 5,760
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5,696
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 66.69
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 21.0 / 43.0
SN Margin (Up/Down) [dB]: 24.0 / 12.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2 / 0
FEC Errors (Up/Down): 89 / 54,138
CRC Errors (Up/Down): 14 / 212
HEC Errors (Up/Down): 12 / 3,593
19-12-2010 10:49 AM
19-12-2010 10:53 AM
19-12-2010 11:20 AM
20-12-2010 8:51 PM
"After 72 hours of constant connection your speeds should return to normal. I this isn't the case, please let us know and we can raise it as a speed fault and have our Faults Team look in to this for you."
My current stats are:
Uptime: 2 days, 7:04:41
Data Transferred (Sent/Received) [kB/GB]: 0.00 / 1.63
SN Margin (Up/Down) [dB]: 24.0 / 10.5
Error Seconds (Local/Remote): 10 / 0
FEC Errors (Up/Down): 241 / 185,959
CRC Errors (Up/Down): 73 / 876
HEC Errors (Up/Down): 50 / 17,060
and BT speedtest shows the following:
Download speedachieved during the test was - 3849 Kbps
Additional Information:
Your DSL Connection Rate :5696 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 4500 Kbps
Does it look like the profile should be raised?
21-12-2010 1:58 AM
The IP profile for your current sync speed is 5000kbps, but since the increase is only 500kbps from your present one it might take 3-5 days to get there.
21-12-2010 8:51 AM
As some others have suggested a reset of your SNR would probably bring up your speed a bit. I've just been having a look at your connection logs and I'd like to wait a bit longer as your line has only been up for just over 2 days. But if it does stay good, I'd be happy to do that, so let me know if you want me to go ahead with that.
Jojo
