Faulty Filtered Faceplate?
minkey
Hi
I have a question regarding an extension I installed which recently dropped my DSL line to 1.4mbs (from over 4).
My setup is as follows:
I have a filtered faceplate on my master socket which is works fine. Recently I ran some (specially purchased) phone wire through my walls from the UNFILTERED terminals of this faceplate to a new filtered faceplate.
I then moved my router to the new faceplate and this was fine until fairly recently when my linespeed dropped to virtually nothing. I've since moved the router back to the original faceplate and my stats have improved.
My question is this - Is is possible to easily tell what the problem is? Have I got a dodgy filtered faceplate (in the new location)? Dodgy wiring? Or is there something else I need to have done?
MJN
Re: Faulty Filtered Faceplate?
You're not plugging the router into the filtered part of the faceplate are you?
If not, it would be worth trying the filtered faceplate connected via a short piece of cable to the unfiltered connections on the master - this would rule out out (or in) the wiring/routing.
minkey
I'm not sure that is possible. The new faceplate only accepts unfiltered inputs (I'm sure I connected to the unfiltered end at the master socket otherwise I would have got no DSL at all) and I plug my router into the plug on front.
MJN
Can you post a link to the exact faceplate you've used?
Fixes: 21
Both at the Master and the Extension, as it would probably be a good idea to get the complete picture.
minkey
Hi
The Extension is a Solwise ADSL-FFP85D (85 mm) http://www.solwise.co.uk/adsl_splitters-extensions.htm
The original faceplate is from ADSL Nation (1 x XTE-2005 Master Faceplate (XTE-2005) ) http://www.adslnation.com/products/xte2005.php
Hope that helps
Jeff
Fixes: 21
I think what I would do - during daylight hours, at least an hour after sunrise and to have finished at least an hour before sunset, is -
Take a copy of your DSL stats whilst plugged into the Filtered XTE-2005 at the master.
Then use this Disconnect method -  log into the modem/router, go to the Internet Session area and click Disconnect to drop the PPP(oA) Internet session to the ISP. Wait a minute and then power down the modem/router. Get a known good dangly "rats-tail" filter remove the XTE2005 faceplate, plug the filter direct into the test socket and connect the modem/router. Ensure you've taken at least 10 minutes since powering down, then power up, log in and click Connect if needed. Take a copy of the DSL stats.
What MJN I believe was suggesting was, on the assumption you have an IDC tool as you connected it all up in the first place - remove the extension face plate from its location (disconnect the wires that is) take a short length of spare twisted pair cable and connect it to the extension plate.
Repeat the Disconnect method above and then remove the filter etc from the Test socket. Remove the extension wiring from the XTE2005 faceplate and connect this short pair with the Extension plate.
Again make sure you've taken at least 10 minutes since powering down - this Disconnect method is to help prevent the Exchange DLM from thinking you have a dropping connection. So now Put the XTE2005 back on the Master and plug into the Extension Filtered plate.
Power up, click Connect and then take a copy of the DSL stats.
You may as well post those 3 lots of stats here before the last stage.
Use the Disconnect method again. Remove the XTE2005 and disconnect the short twisted pair from the plate and the Extension plate. Reconnect the Extension plate back at it's location and reconnect the wiring to the XTE2005 and refit. Again, ensure you've taken  at least 10 minutes, then connect the modem/router and power up, click Connect. Take this last copy of the DSL stats and post them.
HTH.
MJN
Quote from: minkey
Okay that's fine. It was your mention of plugging the modem into a 'filtered faceplate' that had me worried. The modem needs an unfiltered connection. Only telephones (or rather any non-ADSL device) needs a filtered connection. That Solwise is fine given it provides both an unfiltered and filtered socket (and I am assuming you are plugging the modem into the unfiltered side of course!).
I'd follow Anotherone's troubleshooting advice...
minkey
Hi. Sorry only just had a chance to run all the tests. Here are some stats:
Test 1: Router plugged in XTE2005
adsl info expand=enabled
Modemstate                  :  Up
xDSL Type                    :  ADSL
xDSL Standard                :  ITU-T G.992.1
xDSL Annex                  :  Annex A
Channel Mode                :  Interleaved
Uptime (days hh:mm:ss)      :  0 days, 21:41:29
Number of resets            :  2
Total Available Bandwidth          Cells/s          kbit/s
  Downstream                :    13207            5600
  Upstream                  :      2037              864
Bearer Generic Info              Downstream        Upstream
Margin      (dB)            :        9.5            11.0
Attenuation  (dB)            :        41.5            26.5
OutputPower  (dBm)          :        19.5            12.0
Vendor Chipset                      Local            Remote
  Country                    :      B500            B500
  Vendor                    :      IFTN            TSTC
  VendorSpecific            :      3476            0510
  StandardRevisionNr        :        63              63
Vendor System
  Country                    :      0F00            0000
  Vendor                    :      TMMB            ----
  VendorSpecific            :      3C61            0000
  StandardRevisionNr        :        00              00
Transfer statistics
    Errors
      Received FEC          :    52603
      Received CRC          :      151
      Received HEC          :      1254
      Transmitted FEC        :        2
      Transmitted CRC        :        2
      Tranmsitted HEC        :        2
    Near end failures since reset
      Loss of frame          :        0 failures
      Loss of signal        :        0 failures
      Loss of power          :        0 failures
      Errored seconds        :        0 seconds
    Near end failures last 15 minutes
      Loss of frame          :        0 seconds
      Loss of signal        :        0 seconds
      Loss of power          :        0 seconds
    Near end failures current day
    Near end failures previous day
{admin}=
Test 2: Extension connected by short wire to XTE2005
Modemstate                  :  Up
xDSL Type                    :  ADSL
Uptime (days hh:mm:ss)      :  0 days, 0:08:49
  Downstream                :    13584            5760
  Upstream                  :      2037              864
Margin      (dB)            :        9.0            11.0
  Country                    :      B500            B500
  Vendor                    :      IFTN            TSTC
Vendor System
  Country                    :      0F00            0000
  Vendor                    :      TMMB            ----
Transfer statistics
    Errors
      Received FEC          :      725
      Received CRC          :        2
      Received HEC          :      -16
      Transmitted FEC        :        0
      Transmitted CRC        :        0
      Tranmsitted HEC        :        0
      Loss of frame          :      151 failures
      Errored seconds        :        22 seconds
{admin}=
Test 3: Connected to Extension in place
Modemstate                  :  Up
xDSL Type                    :  ADSL
Uptime (days hh:mm:ss)      :  0 days, 0:10:20
Number of resets            :  4
  Downstream                :    10867            4608
  Upstream                  :      2037              864
Margin      (dB)            :        10.0            10.0
Attenuation  (dB)            :        42.5            27.0
  Country                    :      B500            B500
  Vendor                    :      IFTN            TSTC
Vendor System
  Country                    :      0F00            0000
  Vendor                    :      TMMB            ----
Transfer statistics
    Errors
      Received FEC          :        99
      Received CRC          :        0
      Received HEC          :        0
      Transmitted FEC        :        0
      Transmitted CRC        :        0
      Tranmsitted HEC        :        0
      Loss of frame          :      675 failures
      Loss of signal        :        4 failures
      Errored seconds        :    131086 seconds
{admin}=
Test 4: Connected via rat's tail to Test Socket
Modemstate                  :  Up
xDSL Type                    :  ADSL
Uptime (days hh:mm:ss)      :  0 days, 0:01:40
Number of resets            :  5
  Downstream                :    10716            4544
  Upstream                  :      1886              800
Margin      (dB)            :        11.5            11.0
Attenuation  (dB)            :        42.0            27.0
  Country                    :      B500            B500
  Vendor                    :      IFTN            TSTC
Vendor System
  Country                    :      0F00            0000
  Vendor                    :      TMMB            ----
Transfer statistics
    Errors
      Received FEC          :    23793
      Received CRC          :        97
      Received HEC          :    -22733
      Transmitted FEC        :        0
      Transmitted CRC        :        0
      Tranmsitted HEC        :        0
      Loss of frame          :        73 failures
      Loss of signal        :    65537 failures
      Errored seconds        :    196606 seconds
      Loss of signal        :    65533 seconds
      Errored seconds        :    65525 seconds
{admin}=
Please let me know if there are any other scenarios, but it does look like from these stats, that the wire from the master to extension is lowering the sync speed, but I'll leave that to an expert to confirm.
Fixes: 21
I wouldn't agree that it is, because when you plugged into the test socket the sync speed was lower, but also the Noise Margin has gone up.
If you have carried these checks out in daylight as recommended, and you dropped your PPP session before powering down and waited at least 10 minutes between each scenario, the results suggest that either you have a lot of noise on the line anyway (ie. a line fault) or you have been having a bad dropping connection anyway and DLM has possibly raised the Target Noise Margin from 9dB to 12dB.
In any event, taking the initial figures, the line is under-performing for the attenuation, and bearing in mind your OP with the speed previously dropping to 1.4Mbps. If your line was in tip top condition you should be able to get a sync speed nearer 7Mbps with a 6Mbps profile.
If you run the BTw Performance Tester, ignore the red pre-amble and after the first test has completed, click Further Diagnostics at the bottom of the page, then enter your number and run the test, it will give you the Current IP Profile.
You can copy and paste the results into a post (no need to capture an image).
If you are still plugged in at the test socket, have a listen to your line and see if you can hear (or have heard) any crackling or other audible noises. You can dial 17070 select option2 for the Quiet line test if need be. Have you had any problems with incoming or outgoing calls at all?
If you aren't still plugged into the test socket, just carry out the check from the socket you are connected to.
minkey
Stats from BTW:
Download speedachieved during the test was - 4.86 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.11 Mbps
Upload speed achieved during the test was - 0.24Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
The line is quite noisy, although its not connected to the test socket now as I've put it all back together.
I've now logged a fault through the Broadband Troubleshooter as well.
Fixes: 21
Who do you pay line rental to?  This needs to be reported as a phone fault.
minkey
plusnet  Roll eyes
Fixes: 21
Fine, that makes life easy, just make sure you fault ticket makes it obvious it's a phone fault if the trouble shooter didn't point it that way - update the ticket manually, tell them you can hear noises on the line and it's intermittent (the last bit is particularly important). If you want to be certain check with preferably a known good corded phone, & preferably in the test socket (don't forget the Disconnect method)! but at least at the master.
