FTTC - the "missing" Mbps
- FTTC - the "missing" Mbps
Re: FTTC - the "missing" Mbps
11-02-2012 4:34 AM
And right now, while we're in the process of moving house, there isn't any of my "more serious" equipment behind the fibre connection, so that leaves the wife & her laptop, or my daughter... and I don't think there is anything they're doing that regularly.
I can tell, from the way usage accumulates, when they're streaming video in one form or another, and that doesn't match up to any particular flicker on the latency graphs either.
All-in-all, an unknown...
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
13-02-2012 10:52 AM
13-02-2012 11:02 AM
13-02-2012 11:20 AM
13-02-2012 2:23 PM
13-02-2012 5:05 PM
13-02-2012 5:25 PM
It's hard to tell as the graphs lack gridlines, but they seem pretty regular to me! Don't be put off by the dodgy paintshopping either... However, I didn't mean to imply that there was any exact timing when I said "every ~ 2 hours", sorry if that wasn't clear
16-02-2012 7:25 PM
16-02-2012 8:55 PM
16-02-2012 10:00 PM
17-02-2012 8:38 AM
17-02-2012 9:17 AM
If the portal says 37Mb then it is likely you have been lucky and have got a "fast" connection. If you reconnect you will probably be back down to 35Mb.
Accounts which Adam has manually fixed show 20Mb as the current line speed. Presumably the fix has not been rolled out across the whole user base which makes me wonder just how many people have a slow connection and don't realise.
James
17-02-2012 9:33 AM
Here's an updated picture. There was no-one there at all yesterday - so the only load comes from the SamKnows box.
That suggests that the additional latency is coming from somewhere else on the path between TBB and the cabinet, through PlusNet. Do your spikes line up for yesterday (16th), or do they differ?
17-02-2012 2:00 PM
Regards
Chris
<<Added at 10:15pm - Jojo has fixed this and now getting 37M+>>
17-02-2012 2:12 PM
None at all on mine today, although you can only check between midnight - 8 when it was unused. What gateway are you on? pcl-ag01 for me.
