FTTC connection
- FTTC connection
FTTC connection
02-11-2012 6:53 PM
Not sure if anyone else has noticed this on there FTTC connection but the problem im getting is the main router is changing it's ip address all the time yet the openreach modem does'nt lose connection the router im using is a netgear WNR2000 but it also happens with the netgear WNR1000 (plusnet supplied router) it's almost as if its being kicked off the gateway then reconnects but also i have noticed the IP profile has dropped on the fttc conection where as it used to be at 74 to 75Mbps but now at 68 using JackDinns auto speed tester the download speed is showing 59Mbps i don't know if it is possible to have the fttc line profile reset .Though it's not been quite right since openreach dug the road outside mine last week to repair the neighbours line and the openreach engineer knocked out my line completely and had to tell him what he'd done .
James
James
Message 1 of 6
(1,396 Views)
5 REPLIES 5
Re: FTTC connection
04-11-2012 7:27 PM
To add to this i have tried a direct connection into the openreach modem and this is the speed test result this is only since openreach dug up outside to repair a neighbours line the other week. Normally my IP Profile is around 75 - 76Mbps something clearly is not right somewhere yet the plusnet profile is showing 68Mbps
Bt speedtest result
Bt speedtest result
Message 2 of 6
(706 Views)
Re: FTTC connection
04-11-2012 11:21 PM
Plusnet profile is correct for the BT IP profile, if it remains slow then raising a speed fault with Plusnet is probably your best course of action.
Call me 'w23'
Message 3 of 6
(706 Views)
Re: FTTC connection
04-11-2012 11:30 PM
Fault been raised ticket #61842264 though the problem has only occured since openreach dug up outside and hit my phone line causing loss of service but came back in within an hour im wondering if open reach have switched my good line for my neighbours crap line since openreach was doing something to the next door neighbours line.
Message 4 of 6
(706 Views)
Re: FTTC connection
05-11-2012 2:25 PM
Thanks for raising the fault, our agents will get on that and get back to you as soon as you can. Regarding the line swap I suppose this might be possible but there have been no changes to your line details so it's more likely that the cable break was repaired (which could lead to greater interference on the line) rather than the wiring replaced. Either way the fault should get to the bottom of it.
Message 5 of 6
(706 Views)
Re: FTTC connection
05-11-2012 11:57 PM
Message 6 of 6
(706 Views)
