More ADSL problems
- More ADSL problems
More ADSL problems
25-02-2014 2:03 PM
My ADSL broadband has dropped to an unaccebtable speed again. The problem started during last Wednesdays rain and wind. I had a similar problem in January.
BT stats:
1. Best Effort Test: -provides background information.
Download Speed
0.18 Mbps
0 Mbps 0.25 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.18 Mbps
For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
IP Profile for your line is - 0.25 Mbps
Upload Speed
0.38 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.38Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
Zoom 7800N stats
Operational Mode ADSL2+
Upstream 444Kb/ps
Downstream 283Kb/ps
SNR Margin(Upstream) 30.4
SNR Margin(Downstream) 15.4
Line Attenuation(Upstream) 20.3
Line Attenuation(Downstream) 38.5
Could you please look into this and or reset the line
Re: More ADSL problems
25-02-2014 2:10 PM
This is as you surmised.
A better question is why the line degraded so much in the poor weather.
Have you tried raising a fault
25-02-2014 2:51 PM
Sorry to hear about the issues you've had. The line has been banded as the connection is dropping pretty frequently. It looks like things are starting to settle down but I'd still advise raising a fault as this may be due to the weather being more "reasonable" http://faults.plus.net
<img src="http://community.plus.net/visualradius/generated/image13933395172092.png"/>
25-02-2014 6:54 PM
Thanks for your two replies. I have now raised a fault ticket, lets hope we can get to the route of the problem, and find out why the line degrades so much in bad weather. I would expect a line fault somewhere!
27-02-2014 10:14 PM
28-02-2014 9:55 AM
28-02-2014 10:05 AM
03-03-2014 8:20 PM
Thanks for your help, so far so good :).
Upstream 1176
Downstream 10367
SNR Margin(Upstream) 6.6
SNR Margin(Downstream) 1.8
Line Attenuation(Upstream) 20.4
Line Attenuation(Downstream) 38.0
09-03-2014 6:18 PM
DMT Status No Defect
Upstream 352
Downstream 2030
SNR Margin(Upstream) 21.4
SNR Margin(Downstream) 30.1
Line Attenuation(Upstream) 22.9
Download Speed
1.8 Mbps
0 Mbps 2 Mbps
Download speedachieved during the test was - 1.8 Mbps
For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
IP Profile for your line is - 1.79 Mbps
Upload Speed
0.25 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.25Mbps
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
09-03-2014 8:44 PM
Is your fault ticket still open?
09-03-2014 9:08 PM
10-03-2014 9:09 AM
The connections seems to drop when the phone rings. I have already tried changing filters and using the test socket.
Current Stats (9.05am 10/03/2014)
FAQ
Results Image not loaded
Download Speed
5.25 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 5.25 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.29 Mbps
Upload Speed
0.98 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.98Mbps
Router
Upstream 1144
Downstream 5998
SNR Margin(Upstream) 5.8
SNR Margin(Downstream) 5.3
Line Attenuation(Upstream) 21.1
Line Attenuation(Downstream) 36.0
10-03-2014 9:14 AM
There's likely going to be a fault with the Splitter Card at the exchange which we'll need to get looked at for you. Our Faults Team will arrange for an engineer to visit your Local Exchange to get this resolved for you.
Our Faults Team will be in touch in due course.
13-03-2014 9:49 AM
Any news regarding this fault?
My connection is still getting random dropouts!
Latest router stats (09:47 13/03/2014):
No Defect
Upstream 1200
Downstream 3069
SNR Margin(Upstream) 6.5
SNR Margin(Downstream) 8.3
Line Attenuation(Upstream) 20.6
13-03-2014 1:33 PM
I can see that we've arranged for an engineer to attend tomorrow 14/03/2014 between 8AM and 1PM. Hopefully this will resolve the issue you've experienced. Our Faults team will continue to monitor this on Ticket: 81845989.
