FTTC Profile
- Re: FTTC Profile
FTTC Profile
04-10-2011 10:29 AM
Story so far: FTTC Modem failed last friday, BT engineer came yday to replace - did a "template reset" (uhh? would this reset a training period?) after swapping hte modem and i got the best speeds ive ever got (37meg)
Resync at 5:24 this morning (looks like it was an immediate drop and reconnect) - UL speed is still the same, DL speed is now bouncing around like a yo-yo.
Quote Current line speed: 6.5 Mb
Can someone give me a nudge? thinking this might be the problem
is it not possible to stop the system auto-redoing my IP Profile? as this is the second time ive had to get it nudged in just over 7 days.
Regards
Re: FTTC Profile
04-10-2011 10:41 AM
Re: FTTC Profile
04-10-2011 10:42 AM
Re: FTTC Profile
04-10-2011 10:47 AM
Re: FTTC Profile
04-10-2011 10:50 AM
Re: FTTC Profile
05-10-2011 9:36 PM
However, after being set to 37mb, (and the line performing better than it ever has!) i ended up getting the "Snot Green" BT Wholesale page telling me i need to contact my ISP ... So i rebooted the router (Disconnect then connect - Last time this cured the problem!) - Reloaded pages, after huge amount of delay the Snot green page appeared. Marvellous.
Disconnected router, and reset modem.
Reconnect, bing, no problems whatsoever - BUT
The DLM seemed to think i (for some reason?) caused multiple drops (2, and they were 'clean'! ), and has applied Interleaving and has reduced the line to 22meg. (15 meg loss )
I dont mind interleaving, aslong as its at full speed, and i dont mind slow speed, as long as theres super fast latency, Crap latency + poop speed =
Download speedachieved during the test was - 18819 Kbps
For your connection, the acceptable range of speedsis 12000-23637 Kbps .
Additional Information:
IP Profile for your line is -23637 Kbps
When the engineer was here, he did a "template reset" via BT Wholesale, which he said would put it back up to 'full' speed ( im guessing this is another term for SNR reset / reset training period??)
Am i going to have to put up with this speed for ~15 days like before, when the same thing happened under suspiciously similar circumstances?
(this is line #2 from sig, acc = matt2k34)
Many thanks if anything can be done!
Regards
Re: FTTC Profile
06-10-2011 5:48 PM
FYI, the Wholesale landing pages can typically be avoided by hardcoding our DNS addresses into your router.
I'm not sure I'd consider 19Mbps to be a 'poop speed', surely your latency isn't overly bad either?
Re: FTTC Profile
06-10-2011 8:21 PM
2.7MB/s isn't as good as 4.7MB/s 🙂
Is there an ETA on BT rolling out it's system so that you *can* make changes? E.g seen as BT has gone public with it's FTTC/P plans for speed increases next year?
Regards
Re: FTTC Profile
07-10-2011 9:39 AM
Should'nt be any delay and so on, as you said the other day.....
Re: FTTC Profile
07-10-2011 11:26 AM
Quote 2.7MB/s isn't as good as 4.7MB/s 🙂
Clearly references a download speed, during off-peak time
Regards
Re: FTTC Profile
07-10-2011 11:40 AM
Quote from: Matt_2k34 Is there an ETA on BT rolling out it's system so that you *can* make changes? E.g seen as BT has gone public with it's FTTC/P plans for speed increases next year?
Not as yet, though as soon as we know anything (or are able) you'll find out.
Re: FTTC Profile
07-10-2011 9:24 PM
Thanks for your time Bob & Matt
Regards
