FEC CRC and ES errors
lenny
I have been getting drops in my connection  over the last few weeks but this seams to have got worse in the last 7 days , what I have noticed is that when this happens , just before my adsl connection  drops and reconnects  there is a very large increase in FEC  CRC and ES errors , in there thousands for FEC errors and Hundreds  for the others.During the day the error count is very low
I have had everything  turned of in the house apart from the pc and  router and this still happens
My line comes into the house to the master socket with a  mk3 faceplate fitted and there is a data extention from this  which goes for about 10'  and my router plugs into this, I have 1 telephone plugged in to the master socket
adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Max:    Upstream rate = 900 Kbps, Downstream rate = 4224 Kbps
Channel:        INTR, Upstream rate = 448 Kbps, Downstream rate = 3872 Kbps
Link Power State:      L0
Mode:                  G.DMT
TPS-TC:                ATM Mode
Trellis:                ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        5.4            17.0
Attn(dB):        63.5            31.5
Pwr(dBm):        19.0            11.9
                        G.dmt framing
K:              122(0)          15
R:              10              4
S:              1              4
😧              32              8
                        Counters
SF:            1707105        1707118
SFErr:          134382          20
RS:            116083170              29019068
RSCorr:        78611336                33
RSUnCorr:      152151          0
HEC:            56476          11
OCD:            0              7
LCD:            0              2
Total Cells:    264959905              0
Data Cells:    5298984        0
Drop Cells:    0
Bit Errors:    0              0
ES:            21609          0
SES:            135            0
UAS:            372            372
AS:            29021
INP:            1.21            1.00
PER:            1.75            1.75
delay:          8.00            8.00
OR:            32.00          32.00
Bitswap:        2147            8
Total time = 13 hours 57 min 47 sec
FEC:            83198380                0
CRC:            137915          0
ES:            21609          0
SES:            135            0
UAS:            372            372
LOS:            1              0
LOF:            9              0
Latest 15 minutes time = 12 min 47 sec
FEC:            2168985        0
CRC:            8715            0
ES:            697            0
SES:            11              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
Previous 15 minutes time = 15 min 0 sec
FEC:            2503956        0
CRC:            7086            0
ES:            784            0
SES:            0              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
Latest 1 day time = 13 hours 57 min 47 sec
FEC:            83198380                0
CRC:            137915          0
ES:            21609          0
SES:            135            0
UAS:            372            372
LOS:            1              0
LOF:            9              0
Previous 1 day time = 0 sec
FEC:            0              0
CRC:            0              0
ES:            0              0
SES:            0              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
Since Link time = 8 hours 3 min 41 sec
FEC:            78611336                33
CRC:            134382          20
ES:            21334          0
SES:            60              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
This is my ticket number 110142400 ,broadband fault raised
Has anybody any ideas or recommend's please
Chris
58 REPLIES 58
lenny
Re: FEC CRC and ES errors
a few bt reports and stats again
adsl info --stats
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 896 Kbps, Downstream rate = 4768 Kbps
Channel:        INTR, Upstream rate = 448 Kbps, Downstream rate = 4416 Kbps
Mode:                  G.DMT
TPS-TC:                ATM Mode
Trellis:                ON
                Down            Up
SNR (dB):        6.1            17.0
Attn(dB):        63.5            31.5
Pwr(dBm):        19.1            12.1
                        G.dmt framing
K:              139(0)          15
R:              10              4
S:              1              4
😧              32              8
                        Counters
SF:            49677          49617
SFErr:          15              0
RS:            3378066        843489
RSCorr:        137455          0
RSUnCorr:      243            0
HEC:            11              0
OCD:            0              0
LCD:            0              0
Total Cells:    8795807        0
Data Cells:    569443          0
Drop Cells:    0
Bit Errors:    0              0
ES:            10              0
SES:            0              0
UAS:            9              9
AS:            845
INP:            1.07            1.00
PER:            1.75            1.75
delay:          8.00            8.00
OR:            32.00          32.00
Bitswap:        152            3
Total time = 14 min 18 sec
FEC:            137455          0
CRC:            15              0
ES:            10              0
SES:            0              0
UAS:            9              9
LOS:            0              0
LOF:            0              0
Latest 15 minutes time = 14 min 18 sec
FEC:            137455          0
CRC:            15              0
ES:            10              0
SES:            0              0
UAS:            9              9
LOS:            0              0
LOF:            0              0
Previous 15 minutes time = 0 sec
FEC:            0              0
CRC:            0              0
ES:            0              0
SES:            0              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
Latest 1 day time = 14 min 18 sec
FEC:            137455          0
CRC:            15              0
ES:            10              0
SES:            0              0
UAS:            9              9
LOS:            0              0
LOF:            0              0
FEC:            0              0
CRC:            0              0
ES:            0              0
SES:            0              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
Since Link time = 14 min 3 sec
FEC:            137455          0
CRC:            15              0
ES:            10              0
SES:            0              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
lenny
adsl info --stats
Status: Showtime
Retrain Reason: 0
Mode:                  G.DMT
TPS-TC:                ATM Mode
Trellis:                ON
                Down            Up
SNR (dB):        6.6            17.0
Attn(dB):        63.5            31.5
Pwr(dBm):        19.1            12.1
                        G.dmt framing
K:              139(0)          15
R:              10              4
S:              1              4
😧              32              8
                        Counters
SF:            1503201        1503235
SFErr:          476            5
RS:            102217698              25553550
RSCorr:        2978943        65
RSUnCorr:      17563          0
HEC:            357            2
OCD:            12              0
LCD:            0              0
Total Cells:    266124025              0
Data Cells:    2767066        0
Drop Cells:    0
Bit Errors:    0              0
ES:            101            0
SES:            7              0
UAS:            9              9
AS:            25555
INP:            1.07            1.00
PER:            1.75            1.75
delay:          8.00            8.00
OR:            32.00          32.00
Bitswap:        1189            4
Total time = 7 hours 6 min 8 sec
FEC:            2978943        0
CRC:            476            0
ES:            101            0
SES:            7              0
UAS:            9              9
LOS:            0              0
LOF:            0              0
Latest 15 minutes time = 6 min 8 sec
FEC:            27884          0
CRC:            0              0
ES:            0              0
SES:            0              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
FEC:            83013          0
CRC:            2              0
ES:            2              0
SES:            0              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
Latest 1 day time = 7 hours 6 min 8 sec
FEC:            2978943        0
CRC:            476            0
ES:            101            0
SES:            7              0
UAS:            9              9
LOS:            0              0
LOF:            0              0
FEC:            0              0
CRC:            0              0
ES:            0              0
SES:            0              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
Since Link time = 7 hours 5 min 55 sec
FEC:            2978943        65
CRC:            476            5
ES:            101            0
SES:            7              0
UAS:            0              0
LOS:            0              0
LOF:            0              0
lenny
Still happening . and now have crackling on the phone line Sad
lenny
Still getting a burst of errors from 6 to 8 in the evevings and 7to 8 in the mornings  which causes the disconnects, no problem found on my line according  to the reply to my ticking and no response  here from any staff
Anybody have any ideas , there is nothing in the house that's causing this as nothing switches on or off in these times
lenny
I am getting crc errors on the upstream when I use the telephone ,is this normal, my line stats can be found on  MDWS under the name freelander if some one would like to look
Cheers
Chris
Fixes: 251
Quote from: lenny
Hi Chris,
Well that's your issue!  There is no point looking at BB stats whilst the line is noisy.  If PN provide your PHONE service, please use the phone faults link below to report a noisy (intermittently?) phone line fault.  Otherwise, do the same with your phone provider, but do not mention you have a broadband issue to them!
Kevin
lenny
Thanks for reply ,have done loads of quiet line test today and nothing heard , just gad a burst of errors on the line again  and a resync  which coincided with the street lights turning on which follow the same pattern every night , how do I go about this problem please
Fixes: 251
@CRT,
Can you post a VR plot so we can see if there is a clear pattern of problems possibly coincident with the street lights switching on/off.
Any chance of a CLT report please, particularly ac balance.
Thanks,
Kevin
lenny
Thanks Kevin,  there will be a few disconnects  that I have caused in the mornings  , the ones I an concerned  about  with the lights are around the 7.30 to 8.10 pm time and 4.30 to 6.30 am time slots ,
I have been using http://www.mydslwebstats.co.uk ; ( user name freelander ) to monitor  for the last 3 days if you would like to take a look
Chris
Fixes: 251
Hi Chris,
Do not seem to be able to access that.  Think I'll need to take a closer look at the service and establish access to it.
Kevin
lenny
Here is a plot showing errors over 2 days both lots of errors start around 7.45 pm with resync happening at  about 8pm
Fixes: 251
Chris,
That's fab, is there a SNRM plot please?  There is clearly something going on here which is time related.  You might get stability (but at a lower speed) if your force a resynch at night time.  Not ideal, but until we can get the line looked at, it should reduce the level of disconnects.
I've just reread the thread....
If I accept that your reported attenuation is correct, then the line is synching a lot faster than might be reasonably expected.  That could contribute to the error rate.  What does this http://www.kitz.co.uk/adsl/adslchecker.php suggest for line length and speed please?  Also see if 21CN is available on your exchange.
Please keep doing quiet line checks through the evening.  Noise issues can be intermittent and therefore difficult to resolve.
What's the mode being used please?  I'm unlikely to provide insight to its performance, but there are others around here who might.  Have you adjusted any settings to squeeze more speed out of it?
Really need CRT to pick up your fault ticket mentioned in the first post.
Kevin
lenny
Hi
I am on a 20cn exchange  on adsl upto 2mb speed , I use a billion 7800 router which connects at 6db with a sync speed of approx 4242 I have tweaked the snr higher to 7.5db to try and decrease the errors which  worked quite well giving me a stableish speed of 3.5mb up until about 7 days ago when I get these errors which a uses the resync.
Fixes: 251
Chris,
The information you've provided is simply excellent - you've covered all of the major points of investigation in hours which usually takes days.  The SNRM plot is terrible.  There is clearly interference from somewhere.  This needs PlusNET to progress your open fault report.  Hopefully the information you've posted here will be helpful.
It would do no harm to post those images to the support ticket.
I'm suspicious of the reported attenuation, did you look for the reported line length via the previous link I posted?
About all you can do now is to wander around the street lights with a portable AM radio - see http://www.kitz.co.uk/adsl/rein.htm#REIN_identify
HTH,
Kevin
