Extremely slow Speeds!!!
tdmit07
We're paying £24.99 for at LEAST 50mbpb - 60mbps (5MB-6MB), and we're seeing speeds of 5mbps-12mbps (1MB-2MB).
What gives? Our contract doesn't run out until Dec 2023, is this the service we can expect now you have our signature? Damn.
2 REPLIES 2
Mustrum
Fixes: 81
Re: Extremely slow Speeds!!!
Rather than thinking about some conspiracy theory, have you  considered your line may have developed a fault?
Have a look at the Help section, is your phone line noisey would be a good start.
Fixes: 466
@tdmit07
Your speed is not monitored. If you have a speed problem then it has to be reported. The easiest way to do this is to use the mobile phone bot, see. https://www.plus.net/help/report-a-problem/
