Extreme latency and loss of speed - intermittant
- Extreme latency and loss of speed - intermittant
17-11-2015 12:40 AM
Good evening all,
I've had my connection running smoothly for roughly 6 months, during which time I havn't touched a thing - and had zero issues.
However since Saturday, I've been having intermittant drops in speed and huge increases in latency.
For example, 20ms is the normal - however this has been shooting over 500ms (and on a couple of occasions over 1000ms) - during this time, web browsing is slow - and speed drastically decreased (e.g. 1.5mb/s where usual is 17mb/s - ADSL2+)
Nothing in the house has changed - I do run a tweaked SNR margin but, I've ruled that out by defaulting back to the norm and also trying 2 different routers to rule that out (Plusnet's own router died instantly...)
It does seem extremely random, peak time was worst for sure - as its no where near as frequeant now.
I have submitted a support request but, last time I had a problem the "go to no matter what" fix was to increase SNR to a silly level (which didnt help anyway) - so I've instructed them to leave it be!
Any thoughts?
Thanks,
Quote > adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 8000
Last initialization procedure status: 0
Max: Upstream rate = 1196 Kbps, Downstream rate = 18816 Kbps
Bearer: 0, Upstream rate = 1203 Kbps, Downstream rate = 18767 Kbps
Link Power State: L0
Mode: ADSL2+ Annex A
TPS-TC: ATM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 0.6 6.2
Attn(dB): 20.0 11.1
Pwr(dBm): 0.0 12.3
ADSL2 framing
Bearer 0
MSGc: 51 12
B: 222 36
M: 1 1
T: 3 4
R: 0 0
S: 0.3797 0.9769
L: 4699 303
😧 1 1
Counters
Bearer 0
SF: 718597 663466
SFErr: 114 0
RS: 0 512258
RSCorr: 0 0
RSUnCorr: 0 0
Bearer 0
HEC: 89 0
OCD: 4 0
LCD: 4 0
Total Cells: 516250859 33053623
Data Cells: 93334731 4065614
Drop Cells: 0
Bit Errors: 3464 0
ES: 115 0
SES: 0 0
UAS: 142 142
AS: 11665
Bearer 0
INP: 0.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 16.23 17.58
OR: 28.09 8.18
AgR: 18722.86 1207.28
Bitswap: 3561/3561 6/6
Total time = 3 hours 21 min 55 sec
FEC: 0 0
CRC: 115 0
ES: 115 0
SES: 0 0
UAS: 142 142
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 6 min 55 sec
FEC: 0 0
CRC: 3 0
ES: 3 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 0 0
CRC: 9 0
ES: 9 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 3 hours 21 min 55 sec
FEC: 0 0
CRC: 115 0
ES: 115 0
SES: 0 0
UAS: 142 142
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 3 hours 14 min 25 sec
FEC: 0 0
CRC: 114 0
ES: 114 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Any thoughts?
Thanks,
Message 1 of 4
(906 Views)
3 REPLIES 3
Re: Extreme latency and loss of speed - intermittant
17-11-2015 9:45 AM
Message 2 of 4
(482 Views)
17-11-2015 12:51 PM
Just after I believe.
I have setup a TBB Monitoring graph as well, so I will update this thread tonight with that and also router stats if and during when it happens again.
I'm also running a Samknows whitebox - but I don't think that's picked this up due to only testing every so often (can't remember off hand, ever hour or so?!)
Message 3 of 4
(482 Views)
17-11-2015 3:25 PM
Message 4 of 4
(482 Views)
